Stop Console print over the Qt Application (QML)
I’m running a QT application using QML without the X11/Wayland.
To remove the console blinking I run a script at startup with this parameters
echo -e ‘\033[9;0]’ > /dev/tty0
echo -e ‘\033[9;0]’ > /dev/tty1
echo 0 > /sys/class/graphics/fbcon/cursor_blink
But when I have some message in the console (for example remove the ethernet cable and plug again again)
The console will print message over the Qt application.
Someone know how I can fix this?
Thank you.
Caio Pereira
You can disable the Virtual Terminal cursor by using the kernel command line parameter vt.global_cursor_default=0, use the folowing command in the U-Boot command prompt:
setenv defargs ${defargs} vt.global_cursor_default=0
You can also consider disabling the virtual console entirely by removing the kernel configuration CONFIG_VT and/or CONFIG_VT_CONSOLE.
Hi Caio, hide cursor in screen?
Qt5.X
In EGLFS:
export QT_QPA_EGLFS_HIDECURSOR
In FB:
export QT_QPA_FB_HIDECURSOR
Att,
Cleiton Bueno
Blog | Linkedin | B2Open
Cleiton,
I’m using EGLFS and I test with export QT_QPA_EGLFS_HIDECURSOR but didn’t work.
@caiortp, did the U-Boot argument vt.global_cursor_default=0 help or is this still open?
@stefan.agner thank you!
With consoleblank=0 works.
Glad it worked! Note, consoleblank=0 is not the relevant part in this argument string, the relevant part is that console=tty1 is not there anymore…
@caiortp, oh sorry, I clearly did not read your question completely. You can disable the console on tty1 by removing console=tty1 from the kernel command line. U-Boot composes the kernel command line using the setup environment variable, use the following command to remove console=tty1 from the kernel argument list.
setenv setup 'setenv setupargs console=${console},${baudrate}n8 ${memargs} consoleblank=0'
To get rid of the console in any case, removing CONFIG_VT_CONSOLE is certainly an option too.
Regarding cursor, I would still recommend to use vt.global_cursor_default=0 instead of the user space solution, since that makes sure the cursor will not be shown from the very beginning.
@stefan.agner
No didn’t work. I will test remove the CONFIG_VT_CONSOLE.
Tested under apalis-imx6 and it works too. thank you
