Kuzco
July 10, 2019, 8:34am
1
I want to start a m4 application from ocram
to communicate with a7 over rpmsg.
I’m using ARM compiler to compile m4 application.
Compiling the example rpmsg_str_echo_freertos_example
with tcm
scatter file works fine and runs with linux image 2.8b6.
Compiling with ocram
scatter file works and I can start the app.
But there is no communication over rpmsg.
Think # modprobe imx_rpmsg_tty
is ok.
root@colibri-imx7:~# ls /dev/ | grep RPMSG
ttyRPMSG0
I followed this tutorial.
ocram scatter file looks as follow:
#define m_interrupts_start 0x00000000
#define m_interrupts_size 0x00000240
#define m_text_start 0x00910240
#define m_text_size 0x00007DC0
/* m_data_size includes stack and heap */
#define m_data_start 0x20200000
#define m_data_size 0x7800
/* Sizes */
#if (defined(__stack_size__))
#define Stack_Size __stack_size__
#else
#define Stack_Size 0x0200
#endif
#if (defined(__heap_size__))
#define Heap_Size __heap_size__
#else
#define Heap_Size 0x0200
#endif
Also tried a mix scatter file with tcm and ocram:
#define m_text_start 0x1FFF8240
#define m_text_size 0x0000FDB0
#define m_data_size 0x00020000
/* Sizes */
#else
#define Stack_Size 0x8000
#endif
#else
#define Heap_Size 0xE000
#endif
On WinCE, application runs with all three scatter files.
Am I doing something wrong?
Kind regards,
kuzco
HI @Kuzco
Regarding your issue: What are you trying to do?
What is exactly your application?
Have you done any changes to the Bsp? If yes could you share your changes.
Which changes have you done to the free RTOS code?
Kuzco
July 15, 2019, 2:15pm
3
Hi @jaski.tx ,
I try to start the example str_echo_freertos
in ocram
respectively in my mix
scatter file using Arm Compilers 5.
I did not made changes in code. Neither in BSP nor in FreeRTOS.
First I compiled the example as given in tcm
memory (scatter file) with Arm Compilers 5 → works fine.
After that I tried exactly the same only with ocram
scatter file → no communication over rpmsg
between the applications.
On console I can see that application is starting in ocram
. But there is no communication between cores.
kuzco
Kuzco
July 16, 2019, 6:54am
4
Dear @jaski.tx ,
again I tried both examples:
TCM:
Colibri iMX7 # fatload mmc 0:1 ${loadaddr} rpmsg_tcm.elf
reading rpmsg_tcm.elf
4955108 bytes read in 234 ms (20.2 MiB/s)
Colibri iMX7 # bootaux ${loadaddr}
## Starting auxiliary core at 0x1FFF83D9 ...
Colibri iMX7 # boot
colibri-imx7 login: root
Last login: Mon Apr 1 17:34:31 UTC 2019 on ttymxc0
root@colibri-imx7:~# stty -F /dev/ttyRPMSG0 -echo
root@colibri-imx7:~# exec 3<> /dev/ttyRPMSG0
root@colibri-imx7:~# echo Test >&3
root@colibri-imx7:~# cat <&3
Test
^C
root@colibri-imx7:~# exec 3>&-
Exactly what i expected.
OCRAM:
Colibri iMX7 # fatload mmc 0:1 ${loadaddr} rpmsg_ocram.elf
reading rpmsg_ocram.elf
4955112 bytes read in 234 ms (20.2 MiB/s)
## Starting auxiliary core at 0x009103D9 ...
Colibri iMX7 # boot
Last login: Mon Apr 1 17:34:49 UTC 2019 on ttymxc0
[ 73.025169] INFO: rcu_sched self-detected stall on CPU
[ 73.030349] 0-...: (2099 ticks this GP) idle=e99/140000000000001/0 softirq=3597/3597 fqs=1050
[ 73.039047] (t=2100 jiffies g=757 c=756 q=149)
[ 73.043680] Task dump for CPU 0:
[ 73.046908] sh R running task 0 456 385 0x00000002
[ 73.054009] [<8010e12c>] (unwind_backtrace) from [<8010ade0>] (show_stack+0x10/0x14)
[ 73.061762] [<8010ade0>] (show_stack) from [<801b684c>] (rcu_dump_cpu_stacks+0xa8/0xc0)
[ 73.069777] [<801b684c>] (rcu_dump_cpu_stacks) from [<80177064>] (rcu_check_callbacks+0x5a4/0x81c)
[ 73.078745] [<80177064>] (rcu_check_callbacks) from [<8017a17c>] (update_process_times+0x34/0x5c)
[ 73.087624] [<8017a17c>] (update_process_times) from [<8018b30c>] (tick_sched_timer+0x48/0x8c)
[ 73.096242] [<8018b30c>] (tick_sched_timer) from [<8017b1d0>] (__hrtimer_run_queues+0x11c/0x1a8)
[ 73.105034] [<8017b1d0>] (__hrtimer_run_queues) from [<8017b414>] (hrtimer_interrupt+0xa8/0x204)
[ 73.113827] [<8017b414>] (hrtimer_interrupt) from [<805f5430>] (arch_timer_handler_phys+0x28/0x30)
[ 73.122793] [<805f5430>] (arch_timer_handler_phys) from [<8016de3c>] (handle_percpu_devid_irq+0x78/0x138)
[ 73.132366] [<8016de3c>] (handle_percpu_devid_irq) from [<8016931c>] (generic_handle_irq+0x24/0x34)
[ 73.141418] [<8016931c>] (generic_handle_irq) from [<80169820>] (__handle_domain_irq+0x5c/0xb4)
[ 73.150123] [<80169820>] (__handle_domain_irq) from [<80101474>] (gic_handle_irq+0x48/0x8c)
[ 73.158478] [<80101474>] (gic_handle_irq) from [<8010b8cc>] (__irq_svc+0x6c/0x90)
[ 73.165962] Exception stack(0x8d49bd78 to 0x8d49bdc0)
[ 73.171016] bd60: f5aa0000 00000001
[ 73.179197] bd80: 00010000 00300200 8c247f00 00010000 90060400 8c245400 8c24a180 8083235c
[ 73.187379] bda0: 8c245400 0000000a 00400000 8d49bdcc f5aa0020 8047acc0 40000013 ffffffff
[ 73.195566] [<8010b8cc>] (__irq_svc) from [<8047acc0>] (MU_SendMessage+0x28/0x5c)
[ 73.203057] [<8047acc0>] (MU_SendMessage) from [<8060d628>] (imx_rpmsg_notify+0x30/0x44)
[ 73.211154] [<8060d628>] (imx_rpmsg_notify) from [<8047c248>] (virtqueue_kick+0x2c/0x50)
[ 73.219250] [<8047c248>] (virtqueue_kick) from [<8060cc64>] (rpmsg_send_offchannel_raw+0x264/0x318)
[ 73.228300] [<8060cc64>] (rpmsg_send_offchannel_raw) from [<8060ce30>] (virtio_rpmsg_send+0x2c/0x34)
[ 73.237446] [<8060ce30>] (virtio_rpmsg_send) from [<7f020130>] (rpmsgtty_write+0x48/0x8c [imx_rpmsg_tty])
[ 73.247025] [<7f020130>] (rpmsgtty_write [imx_rpmsg_tty]) from [<8048a75c>] (do_output_char+0x160/0x1e4)
[ 73.256510] [<8048a75c>] (do_output_char) from [<8048b75c>] (n_tty_write+0x204/0x440)
[ 73.264345] [<8048b75c>] (n_tty_write) from [<80486f1c>] (tty_write+0x180/0x358)
[ 73.271749] [<80486f1c>] (tty_write) from [<801fda8c>] (__vfs_write+0x1c/0x110)
[ 73.279064] [<801fda8c>] (__vfs_write) from [<801fe90c>] (vfs_write+0xa4/0x1b0)
[ 73.286380] [<801fe90c>] (vfs_write) from [<801ff9e4>] (SyS_write+0x3c/0x90)
[ 73.293436] [<801ff9e4>] (SyS_write) from [<80107580>] (ret_fast_syscall+0x0/0x48)
[ 100.005174] NMI watchdog: BUG: soft lockup - CPU#0 stuck for 23s! [sh:456]
[ 100.012064] Modules linked in: bluetooth(O) compat(O) usb_f_rndis u_ether imx_rpmsg_tty libcomposite configfs
[ 100.022094] CPU: 0 PID: 456 Comm: sh Tainted: G O 4.9.166-2.8.6+gd899927728be #1
[ 100.030617] Hardware name: Freescale i.MX7 Dual (Device Tree)
[ 100.036365] task: 8c51f300 task.stack: 8d49a000
[ 100.040907] PC is at MU_SendMessage+0x28/0x5c
[ 100.045266] LR is at 0xf5aa0020
[ 100.048410] pc : [<8047acc0>] lr : [<f5aa0020>] psr: 40000013
[ 100.048410] sp : 8d49bdcc ip : 00400000 fp : 0000000a
[ 100.059888] r10: 8c245400 r9 : 8083235c r8 : 8c24a180
[ 100.065114] r7 : 8c245400 r6 : 90060400 r5 : 00010000 r4 : 8c247f00
[ 100.071642] r3 : 00300200 r2 : 00010000 r1 : 00000001 r0 : f5aa0000
[ 100.078173] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 100.085309] Control: 10c5387d Table: 8d4ac06a DAC: 00000051
[ 100.091057] CPU: 0 PID: 456 Comm: sh Tainted: G O 4.9.166-2.8.6+gd899927728be #1
[ 100.099580] Hardware name: Freescale i.MX7 Dual (Device Tree)
[ 100.105344] [<8010e12c>] (unwind_backtrace) from [<8010ade0>] (show_stack+0x10/0x14)
[ 100.113094] [<8010ade0>] (show_stack) from [<8040dc8c>] (dump_stack+0x88/0x9c)
[ 100.120325] [<8040dc8c>] (dump_stack) from [<801a03b8>] (watchdog_timer_fn+0x260/0x2d8)
[ 100.128337] [<801a03b8>] (watchdog_timer_fn) from [<8017b1d0>] (__hrtimer_run_queues+0x11c/0x1a8)
[ 100.137216] [<8017b1d0>] (__hrtimer_run_queues) from [<8017b414>] (hrtimer_interrupt+0xa8/0x204)
[ 100.146009] [<8017b414>] (hrtimer_interrupt) from [<805f5430>] (arch_timer_handler_phys+0x28/0x30)
[ 100.154976] [<805f5430>] (arch_timer_handler_phys) from [<8016de3c>] (handle_percpu_devid_irq+0x78/0x138)
[ 100.164551] [<8016de3c>] (handle_percpu_devid_irq) from [<8016931c>] (generic_handle_irq+0x24/0x34)
[ 100.173603] [<8016931c>] (generic_handle_irq) from [<80169820>] (__handle_domain_irq+0x5c/0xb4)
[ 100.182307] [<80169820>] (__handle_domain_irq) from [<80101474>] (gic_handle_irq+0x48/0x8c)
[ 100.190663] [<80101474>] (gic_handle_irq) from [<8010b8cc>] (__irq_svc+0x6c/0x90)
[ 100.198146] Exception stack(0x8d49bd78 to 0x8d49bdc0)
[ 100.203200] bd60: f5aa0000 00000001
[ 100.211382] bd80: 00010000 00300200 8c247f00 00010000 90060400 8c245400 8c24a180 8083235c
[ 100.219565] bda0: 8c245400 0000000a 00400000 8d49bdcc f5aa0020 8047acc0 40000013 ffffffff
[ 100.227749] [<8010b8cc>] (__irq_svc) from [<8047acc0>] (MU_SendMessage+0x28/0x5c)
[ 100.235240] [<8047acc0>] (MU_SendMessage) from [<8060d628>] (imx_rpmsg_notify+0x30/0x44)
[ 100.243337] [<8060d628>] (imx_rpmsg_notify) from [<8047c248>] (virtqueue_kick+0x2c/0x50)
[ 100.251433] [<8047c248>] (virtqueue_kick) from [<8060cc64>] (rpmsg_send_offchannel_raw+0x264/0x318)
[ 100.260482] [<8060cc64>] (rpmsg_send_offchannel_raw) from [<8060ce30>] (virtio_rpmsg_send+0x2c/0x34)
[ 100.269627] [<8060ce30>] (virtio_rpmsg_send) from [<7f020130>] (rpmsgtty_write+0x48/0x8c [imx_rpmsg_tty])
[ 100.279204] [<7f020130>] (rpmsgtty_write [imx_rpmsg_tty]) from [<8048a75c>] (do_output_char+0x160/0x1e4)
[ 100.288689] [<8048a75c>] (do_output_char) from [<8048b75c>] (n_tty_write+0x204/0x440)
[ 100.296524] [<8048b75c>] (n_tty_write) from [<80486f1c>] (tty_write+0x180/0x358)
[ 100.303927] [<80486f1c>] (tty_write) from [<801fda8c>] (__vfs_write+0x1c/0x110)
[ 100.311244] [<801fda8c>] (__vfs_write) from [<801fe90c>] (vfs_write+0xa4/0x1b0)
[ 100.318560] [<801fe90c>] (vfs_write) from [<801ff9e4>] (SyS_write+0x3c/0x90)
[ 100.325616] [<801ff9e4>] (SyS_write) from [<80107580>] (ret_fast_syscall+0x0/0x48)
Don’t know what all the messages mean.
I can send you the binary .elf files.
OCRAM example is compiled with the scatter file mentioned above.
Hope this helps.
Kind regards,
kuzco
Dear @Kuzco
Linux seems to somewhat use two OCRAM ranges:
4kB at the start of OCRAM
0x2020_0000 - 0x2020_0FFF
/ 0x0090_0000 - 0x0090_0FFF
60kB at offset 0x1000
0x2020_1000 - 0x2020_FFFF
/ 0x0090_1000 - 0x0090_FFFF
I verified that the first 4kB get overwritten during Linux boot, the other 60kB seem to be left untouched.
I didn’t analyze in detail which Linux functionality uses the memory, and how to disable it.
Can you try to modify your scatter file to not use the first 4kB?
Regards, Andy
Kuzco
August 1, 2019, 1:26pm
6
Dear @andy.tx ,
thanks for your answer.
It seems that this is a solution.
Now the str_echo_freertos
example and my own M4 application are running with ocram
and my mix
scatter file.
Thank you!
Kind regards,
kuzco
