Hi @alex.tx ,
Executable is working code, once it was almost ready to release/tested, then only I decided to add on boot-up. Booting agv_test log for your ref.
root@colibri-imx7-emmc:~# /usr/bin/agv_test
sysinfo_main() called thread ID: 0
System Time:i2c_main() called thread ID: 1
i2c_dev_open() called bus_num: 0
i2c_dev_open() called bus_num: 2
i2c_dev_open() called bus_num: 3
timer_main() called thread ID: 5
camera_main() called thread ID: 6
motor_main() called thread ID: 7
diags_main() called thread ID: 8
sensor_main() called thread ID: 9
wifi_main() called thread ID: 10
rtc_main() called thread ID: 11
usb_main() called thread ID: 12
ps_main() called thread ID: 13
indicator_main() called thread ID: 14
Could you please help me on this? let me know if you need any more details.
Your app may work OK when started form CLI but it doesn’t work when you starting it as a service. May be it relay on some environment variables which does not exists when systemd launch it. Or something else. Unfortunately I can’t debug your app.
Hi @alex.tx
I understand what you say. Let me make one test code just having void main(void) and print, return 0. and update you my findings.
and then I can debug more on what are the dependencies my app has.
Hi @alex.tx ,
I verified with my test code and noticed as soon as I login and type anything. my executable launches. is that the right behavior?
The Angstrom Distribution colibri-imx7-emmc ttymxc0
Angstrom v2017.12 - Kernel
Colibri-iMX7-eMMC_Console-Image 2.8b6 20191122
colibri-imx7-emmc login: root
Last login: Tue Feb 18 11:56:26 UTC 2020 on ttymxc0
root@colibri-imx7-emmc:~# ls /usr/bin
main() started…
It depends on your test app. Are you trying to interact with default console? Change you test app for just creating a file and check if file is created. Use an absolute path for file location please.
