Device : iMX8mp
OS: Torizon OS 6.x.x latest.
I want to launch my GUI application on boot, for that I created a custom weston-vivante docker image which contains all the libraries as well as my application. When I create a container using that image with `docker run -e ACCEPT_FSL_EULA=1 -d --rm --name=weston --net=host --cap-add CAP_SYS_TTY_CONFIG \
-v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ \
--device-cgroup-rule='c 4:* rmw' --device-cgroup-rule='c 13:* rmw' \
--device-cgroup-rule='c 199:* rmw' --device-cgroup-rule='c 226:* rmw' \
myimagename:mytag --tty=/dev/tty7`
a container is started, then I get into container with docker exec -it container-name /bin/bash
, go to directory, run the ./app and application runs fine.
Since I want all this to happen automatically at boot I created yaml file at /var/sota/storage/docker-compose/docker-compose.yml
version: "3.9"
services:
weston:
image: torizon/weston${GPU}:3
container_name: weston-tor
environment:
- ACCEPT_FSL_EULA=1
# Required to get udev events from host udevd via netlink
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /run/udev
target: /run/udev
cap_add:
- CAP_SYS_TTY_CONFIG
# Add device access rights through cgroup...
device_cgroup_rules:
# ... for tty0
- "c 4:0 rmw"
# ... for tty1
- "c 4:1 rmw"
# ... for tty7
- "c 4:7 rmw"
# ... for /dev/input devices
- "c 13:* rmw"
- "c 199:* rmw"
# ... for /dev/dri devices
- "c 226:* rmw"
the above file works fine but as soon as I try to add command variable or entrypoint variable and try to launch even weston-flower , the container doesn’t starts.
I also, tried to add cmd variable in the dockerfile while creating container image, the container starts but app is not launched.
What can I do in this case.
Greetings @Sudharshan,
If I understand correctly you’re trying to use the Weston container to launch another process? If so then this does not work like you think it will.
The weston container already has an entrypoint. That is the process that starts the Weston compositor. If you overwrite this process with another one, then weston won’t start.
What you should do is launch weston as one container to start and manage the Weston process. Then start a completely different container that then launches the graphical app you want. Look at the example here: Debian Containers for Torizon | Toradex Developer Center
We launch one container for the Weston compositor. Then we launch a 2nd separate container for weston-terminal
Hi @jeremias.tx ,
As I’m on iMX8mp, when I run the first command to start weston, the compositor is up, but when I create a second container wayland-app , firstly the container is just not created with --rm flag , without -rm flag it gets created but exits immediately , also the weston-terminal doesn’t starts since the wayland-app container exits with
torizon@verdin-imx8mp-14753765:~/final$ docker logs wayland-app
Switching VT tty7 to text mode if currently in graphics mode
Couldn't open /dev/tty7
I see the portainers runs the way you are telling , even when I create application with vscode templates the weston container is separate and application container is separate. But these two commands when running subsequently doesn’t works for me.
And If I’m running a GTK application by having separate containers, one container would be weston vivante for compositor. The second container where my app will reside shall be based on which container , debian or wayland?
Regards
Hi @Sudharshan ,
Kindly share your docker run command without -d flag, alos share any logs you get to further check.
additionally please share output of below commands
sudo tdx-info
docker ps
docker ps -a
docker ps -q
docker images
I believe you can use Debian based Docker image with proper gtk packages to run gtk application with wayland backend.
Ritesh Kumar
Hi @ritesh.tx
PFB
Software summary
Bootloader: U-Boot
Kernel version: 5.15.129-6.4.0+git.67c3153d20ff #1-TorizonCore SMP PREEMPT Wed Sep 27 12:30:36 UTC 2023
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/460c0c1dde52ce6a4fd14e6ff7399ad1c879175a9ffa047acbb97523d9376591/0
Distro name: NAME="TorizonCore"
Distro version: VERSION_ID=6.4.0-build.5
Hostname: verdin-imx8mp-14753765
Hardware info
HW model: Toradex Verdin iMX8M Plus on Verdin Development Board
Toradex version: 0063 V1.1A
Serial number: 14753765
Processor arch: aarch64
torizon@verdin-imx8mp-14753765:~$ docker ps
f19a28e1a213 torizon/weston-vivante:3 "/usr/bin/entry.sh -…" 4 weeks ago Up About an hour weston
torizon@verdin-imx8mp-14753765:~$ docker ps -a
d405630118f1 mywaylandapp:1.0 "/bin/bash" 17 minutes ago Exited (255) 12 minutes ago xenodochial_hypatia
4b636991758d torizon/weston-vivante:3 "/usr/bin/entry.sh -…" 6 days ago Exited (1) 44 hours ago weston1
torizon@verdin-imx8mp-14753765:~$ docker ps -q
f19a28e1a213
torizon@verdin-imx8mp-14753765:~$ docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
mywaylandapp 1.0 b2aeec4771d2 About an hour ago 407MB
kiwi 3 983319ae6119 18 hours ago 760MB
torizon/weston 3 ca8609dea4a7 44 hours ago 364MB
torizon/debian 3.3-bookworm 786f4bbef578 44 hours ago 115MB
torizon/weston-vivante 3 b9630cbc2309 2 months ago 515MB
torizon/weston-vivante 3.2 b9630cbc2309 2 months ago 515MB
torizon/debian 3.2.1-bookworm 470107e5e0f4 2 months ago 115MB
torizon/weston-vivante 2 eb17fa1e613f 18 months ago 424MB
Created mywayland app with below dockerfile
torizon@verdin-imx8mp-14753765:~/bla$ cat Dockerfile
# Specify the target architecture
ARG IMAGE_ARCH=linux/arm64
# Specify the base image name
ARG BASE_NAME=torizon/debian
# Specify the image tag
ARG IMAGE_TAG=3.3-bookworm
# Specify the Docker registry
ARG DOCKER_REGISTRY=torizon
# Use multi-stage build and specify the target platform
FROM --platform=$IMAGE_ARCH $BASE_NAME:$IMAGE_TAG AS base
# Install aptitude
RUN apt-get update && \
apt-get install -y aptitude
# Install unicode
RUN apt-get install -y libicu-dev
# Accept all unmet dependencies confirmation thrown by aptitude
RUN aptitude -y install libwxgtk3.2-1
# Copy your application (assuming it's in the current directory)
COPY path/home/torizon/dir
# Set the working directory
WORKDIR /home/torizon/dir
docker run -e ACCEPT_FSL_EULA=1 -d --rm --name=wayland-app \
-v /dev/dri:/dev/dri -v /dev/galcore:/dev/galcore -v /tmp:/tmp \
mywaylandapp:1.0 ./build/app
When I run a container from above image, with above command ,my app fails to start following log
torizon@verdin-imx8mp-14753765:~/bla$ docker logs wayland-app
12:30:41: Error: Unable to initialize GTK+, is DISPLAY set properly?
Please ignore the directory I’ve changes it for posting here. Its just that my second container cannot use weston for some reason when I’m trying to run it.
Regards
Hi @jeremias.tx ,
I tried the example given here. It works in one go and runs the example application.
I modified the dockerfile as per my requirement, installed the required, libraries , and tried to up with docker compose yet only the weston container run, the application container exits with below message.
torizon@verdin-imx8mp-14753765:~/ex$ docker logs ex-pysimplegui-1
17:10:22: Error: Unable to initialize GTK+, is DISPLAY set properly?
Is there any additional configuration needed to run GTK application? from different container.
I also tried torizon-samples/opencv/docker-compose.yaml at bookworm · toradex/torizon-samples · GitHub as it uses GTK.
that too fails with below logs
[+] Running 3/3
✔ Network opencv_default Created 0.1s
✔ Container opencv-weston-1 Created 2.4s
✔ Container opencv-opencv-example-1 Created 0.1s
Attaching to opencv-opencv-example-1, opencv-weston-1
opencv-weston-1 exited with code 1
opencv-opencv-example-1 exited with code 1
torizon@verdin-imx8mp-14753765:~/opencv$ docker logs opencv-opencv-example-1
File "/home/torizon/opencv-example.py", line 6, in <module>
cv2.imshow('image',img)
cv2.error: OpenCV(4.6.0) ./modules/highgui/src/window_gtk.cpp:635: error: (-2:Unspecified error) Can't initialize GTK backend in function 'cvInitSystem'
torizon@verdin-imx8mp-14753765:~/opencv$ docker logs opencv-weston-1
Switching VT tty1 to text mode if currently in graphics mode
Couldn't open /dev/tty1
torizon@verdin-imx8mp-14753765:~/opencv$ docker ps
torizon@verdin-imx8mp-14753765:~/opencv$ docker start weston1
weston1
Regards
Well it’s hard to say what the issue here is exactly since it’s based on your modifications.
I can confirm this sample is outdated.
Perhaps you can take a look at our templates repository that is used by our VSCode extension: GitHub - toradex/vscode-torizon-templates: VS Code Torizon Integrated Development Environment Templates
These are meant to be used with our extension: Visual Studio Code IDE Extension | Toradex Developer Center
But, they can be used as a reference as well. Some of the templates here use GTK.
HI @Sudharshan,
I believe you need to set GDK_BACKEND=wayland before running gtk application. Can you check with same and see if this works for gtk application.
Best regards
Ritesh Kumar
Hi @ritesh.tx ,
Tried running it this way, weston compositor is already up , running the application container.
docker run --rm -it -e GDK_BACKEND=wayland -e DISPLAY=:0 mydockerimage:latest
Please correct me if I’m setting it up in wrong way.
Still got the same gtk display issue.
I tried out the Avalonia.net template in VS code which uses GTK
RUN apt-get -y update && apt-get install -y --no-install-recommends \
# ADD YOUR PACKAGES HERE
# DO NOT REMOVE THIS LABEL: this is used for VS Code automation
# __torizon_packages_dev_start__
# __torizon_packages_dev_end__
libice6 \
libsm6 \
libicu72 \
curl \
gettext \
apt-transport-https \
libx11-6 \
libunwind-13 \
icu-devtools \
libfontconfig1 \
libgtk-3-0 \
libgtk-3-bin \
libgtk-3-common \
libdrm2 \
libinput10 \
libssl3 \
&& apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
the sample Avalonia application runs in one go.
So, two things here,
- You suggested to have separate containers for weston and my GTK application, but here with the template I can see the Avalonia application running on single container,
3ac5bb953616 172.17.54.146:5002/gtk:arm64 "/usr/sbin/sshd -D" About a minute ago Up About a minute torizon-gtk-debug-1
how does that work? I see both weston and avolonia has different entry script. I would still prefer to have a single container running(if possible).
- On that very same running container, I installed my application libraries, put the application binary and ran my application, again got the same error.
15:51:08: Error: Unable to initialize GTK+, is DISPLAY set properly?
FYI, I’ve built my application with wxWidgets.
Samarth
Which avalonia template are you using? There’s 2 in the repository. One definitely needs weston as a supplementary container. The other runs directly on the framebuffer which is why it doesn’t need weston. But not all graphics frameworks can be easily ran on the framebuffer so this isn’t generally applicable.
Again are you running on the avalonia template that requires weston or the framebuffer one? If you’re running on the framebuffer one then maybe your application can’t run on framebuffer and requires weston/wayland.
We have not done have much testing with wxWidgets on our systems. It’s hard to say what the issue is here.
I’ve used the one using FB can confirm based upon the docker compose file, should have used the GTK one. The idea was to use the template and modify the Dockerfile, and run my app in multi container environment. Will check the one with weston, and let you know. Thanks.
Regards
Samarth
@jeremias.tx
Was able to get my app working with the avonia GTK container, which uses common/torizon-imx8 for display.
Thanks & regards.
Glad we were able to help get you started!
