In apalis t30(Linux apalis-t30 3.1.10) SSD is not detecting.
With the same setup, HDD is detecting and able to create and delete files in the HDD but in the same board SSD is not detecting.
So does apalis T30 supports SSD by default? What are the changes needed to support the SSD?
hi
which ssd are you connecting to the board? Are you getting any messages when connecting/disconnecting ssd?
send the log of lsusb, please?
Hi Jaski,
Please find the required details:
ssd details: Samsung SSD 850 pro 1TB
P/N: MZ7KE1T0
Model: MZ-7KE1T0
MSIP: REM-SEC-MZ-7KE1T0
S/N: S252NX0H707707R
Rated: DC+5.0V---1.5A
I think SSD is detected from the kernel but but not getting mounted. Rotational value is “0”, that means SSD is detected from the kernel.
root@apalis-t30:~# cat /sys/block/sda/queue/rotational 0
root@apalis-t30:~#
And once tried to get the /dev nodes details for the SSD through “fdisk -l” it shows /dev/sda node for the SSD and the size of the SSD. After creating the new partition once tried to mount the new, it was throwing file system type error.
Please find the attched debug logs for the SSD.
root@apalis-t30:~# lsusb
Bus 001 Device 002: ID 8564:1000 Transcend Information, Inc. JetFlash
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@apalis-t30:~#
root@apalis-t30:~# fdisk -l
Disk /dev/sda: 1024.2 GB, 1024209543168 bytes
255 heads, 63 sectors/track, 124519 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/sda1 * 1 45 358400 7 HPFS/NTFS
Partition 1 does not end on cylinder boundary
/dev/sda2 45 10199 81561600 7 HPFS/NTFS
/dev/sda3 10199 124520 918282240 6 FAT16
Disk /dev/mmcblk0: 7818 MB, 7818182656 bytes
4 heads, 32 sectors/track, 119296 cylinders
Units = cylinders of 128 * 512 = 65536 bytes
/dev/mmcblk0p1 65 320 16384 c Win95 FAT32 (LBA)
/dev/mmcblk0p2 321 118880 7587840 83 Linux
Disk /dev/mmcblk0boot1: 4 MB, 4194304 bytes
4 heads, 16 sectors/track, 128 cylinders
Units = cylinders of 64 * 512 = 32768 bytes
Disk /dev/mmcblk0boot1 doesn't contain a valid partition table
Disk /dev/mmcblk0boot0: 4 MB, 4194304 bytes
Disk /dev/mmcblk0boot0 doesn't contain a valid partition table
Disk /dev/sdb: 7822 MB, 7822376960 bytes
5 heads, 13 sectors/track, 235047 cylinders
Units = cylinders of 65 * 512 = 33280 bytes
/dev/sdb1 2 235048 7638976 c Win95 FAT32 (LBA)
root@apalis-t30:~#
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7 |
0
root@apalis-t30:~#
hi deepak,
the SDD is detected and mounted by the module. Could you send the output of mount?
Hi Jaski,
Thank you for confirming this.
Now i don’t have logs for the “mount” command(Because SSD is at the client place). But i tried to use “mount” command and mount command didn’t shows the mount point for the SSD. I also tried to format the SSD through fdisk command and created new partition. When trying to mount that partition i was getting error file system type error. So do i need to create any specific file system?
Hi Jaski,
I have got the “mount” command logs for the. But still is SSD not mounted.
Which file format Apalis T30 supports?
From the fdisk command it looks like new partitions for the SSD are NTFS. So does NTFS file format supports?
logs:
root@apalis-t30:~# mount
/dev/mmcblk0p2 on / type ext3 (rw,noatime,errors=continue,user_xattr,acl,barrier=1,data=writeback)
devtmpfs on /dev type devtmpfs (rw,relatime,mode=755)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup
(rw,nosuid,nodev,noexec,relatime,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
tmpfs on /tmp type tmpfs (rw)
tmpfs on /var/volatile type tmpfs (rw,relatime)
/dev/mmcblk0p1 on /media/mmcblk0p1 type vfat (rw,relatime,gid=6,fmask=0007,dmask=0007,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shor)
tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=203992k,mode=700)
root@apalis-t30:~# df -Th
Filesystem Type Size Used Available Use% Mounted on
/dev/root ext3 7.1G 437.5M 6.7G 6% /
devtmpfs devtmpfs 996.0M 0 996.0M 0% /dev
tmpfs tmpfs 996.0M 0 996.0M 0% /dev/shm
tmpfs tmpfs 996.0M 404.0K 995.7M 0% /run
tmpfs tmpfs 996.0M 0 996.0M 0% /sys/fs/cgroup
tmpfs tmpfs 996.0M 4.0K 996.0M 0% /tmp
tmpfs tmpfs 996.0M 0 996.0M 0% /var/volatile
/dev/mmcblk0p1 vfat 16.0M 4.0M 11.9M 25% /media/mmcblk0p1
tmpfs tmpfs 199.2M 0 199.2M 0% /run/user/0
root@apalis-t30:~#
NTFS should not be used for Linux. Use exfat4 or some other useful FileSystem.
Hi Jaski,
Today i got SSD, after creating the ext3 partition SSD is detecting in T30.
But i am not getting anything related to SSD while using “lsusb”. So does “lsusb” command lists the SSD details?
logs:
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
/dev/sda1 on /media type ext3 (rw,relatime,sync,errors=continue,user_xattr,acl,barrier=1,data=writeback)
/dev/mmcblk0p1 on /run/media/root/boot type vfat (rw,nosuid,nodev,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,)
root@apalis-t30:~#
root@apalis-t30:~#
If you connect a SSD using USB, it should definitely appear in lsusb…
Are you using USB based SSD drives?
If yes, can you try to connect when the system is fully booted and see whether there are any kernel messages printed when plugging-in?
Hi Stefan,
I am connecting SSD through SATA cable, thats why lsusb is not showing SSD details. but i can see the mount point for the SSD.
With “I can see the mount point” you mean the kernel creates the device file(s) under /dev (e.g. sdaX)?
Which version are you using? Our 2.8b1 had a regression that automount does not work anymore, see issue #34155.
You can manually fix by removing MountFlags=slave in /lib/systemd/system/systemd-udevd.service.
Hi Stefan,
SSD was not auto mounted.
kernel version : Linux apalis-t30 3.1.10
After connecting the SSD through SATA cable, i have formated the SSD through “fdisk /dev/sda” and created a node sda1 and then formated sda1 node through mkfs.ext3. After creating ext3 partition for sda1 i have manually mounted /dev/sda1 to /mnt. Then after reboot i was able to see mount point for the sda1 and able to read and write.
Yes that make sense, there need to be a valid partition table/partition and file system on the drive for auto mount to work.
Thanks for letting us know.
