We have done some testing on 1PPS generation from the Freescale Ethernet Controller (FEC) core using the IEEE1588 event functionality. Below is the contents of a linux kernel trace ringbuffer from a modified version of the fec_ptp driver. This log shows the contents of various variables and registers in the interrupt handler (which manages 1PPS generation), in the fec_time_keep 1Hz thread, and in the fec_ptp_adjfreq function:
<idle>-0 [000] d.H1 4019.134805: fec_pps_interrupt: Update PPS counter 2a76ec29 3341a71a
ptp4l-704 [001] d..1 4019.144413: fec_ptp_adjfreq: Set ATIME_INC 90a 6ac3
ptp4l-704 [001] d..1 4019.207961: fec_ptp_adjfreq: Set ATIME_INC 90a 6ad7
ptp4l-704 [002] d..1 4019.270849: fec_ptp_adjfreq: Set ATIME_INC 90a 6e90
ptp4l-704 [002] d..1 4019.334350: fec_ptp_adjfreq: Set ATIME_INC 90a 6b3b
ptp4l-704 [002] d..1 4019.397134: fec_ptp_adjfreq: Set ATIME_INC 90a 6aa6
ptp4l-704 [000] d..1 4019.460869: fec_ptp_adjfreq: Set ATIME_INC 90a 6ab3
ptp4l-704 [001] d..1 4019.524047: fec_ptp_adjfreq: Set ATIME_INC 90a 6ac9
kworker/2:1-33 [002] d..1 4019.586853: fec_time_keep: Read ns 17a8da30e270b80a
ptp4l-704 [001] d..1 4019.588091: fec_ptp_adjfreq: Set ATIME_INC 90a 6aad
ptp4l-704 [001] d..1 4019.651044: fec_ptp_adjfreq: Set ATIME_INC 90a 6adb
ptp4l-704 [000] d..1 4019.714924: fec_ptp_adjfreq: Set ATIME_INC 90a 6ae6
ptp4l-704 [001] d..1 4019.778404: fec_ptp_adjfreq: Set ATIME_INC 90a 6ac6
ptp4l-704 [001] d..1 4019.841837: fec_ptp_adjfreq: Set ATIME_INC 90a 6ad3
ptp4l-704 [001] d..1 4019.905513: fec_ptp_adjfreq: Set ATIME_INC 90a 6abc
ptp4l-704 [001] d..1 4019.969035: fec_ptp_adjfreq: Set ATIME_INC 90a 6ab8
ptp4l-704 [001] d..1 4020.032870: fec_ptp_adjfreq: Set ATIME_INC 90a 6aa3
ptp4l-704 [002] d..1 4020.096327: fec_ptp_adjfreq: Set ATIME_INC 90a 6aba
<idle>-0 [000] d.h1 4020.135108: fec_pps_interrupt: Update PPS counter 6611b629 6ee0a8dc
ptp4l-704 [002] d..1 4020.159852: fec_ptp_adjfreq: Set ATIME_INC 90a 6a93
ptp4l-704 [001] d..1 4020.223303: fec_ptp_adjfreq: Set ATIME_INC 90a 6af5
ptp4l-704 [001] d..1 4020.287059: fec_ptp_adjfreq: Set ATIME_INC 90a 6af0
ptp4l-704 [003] d..1 4020.350293: fec_ptp_adjfreq: Set ATIME_INC 90a 6abf
ptp4l-704 [003] d..1 4020.412766: fec_ptp_adjfreq: Set ATIME_INC 90a 6ab9
<idle>-0 [000] d.h1 4020.422387: fec_pps_interrupt: Update PPS counter 21ac8029 1445
The symptom that we see is spurious interrupts. In this log, we see 2 true interrupts at kernel ticks 4019.134805 and 4020.135108 and a spurious interrupt at 4020.422387. The first two interrupts were approximately 1second apart, but the spurious interrupt is about 190ms after the previous interrupt. When the spurious interrupt fires, we see that the counter time register ATIME was 0x1445, not just after 0x2a76ec29 as was programmed into the match register at time 4019.134805.
The spurious interrupt also triggers the event pin, so we see a spurious pulse on an oscilloscope (with infinite persistence triggered from GPS 1PPS) and on a SRS FS740 Time Frequency system.
To me, this looks like a silicon issue.
Has anyone come across something similar?
