Splash screen for imx6
I cannot perform the BMP to TSS file conversion for you(1). Based on the community discussion, this conversion requires specific tools and knowledge that only Toradex support has access to(1).
What You Need to Do
The recommended process is to contact Toradex support directly with your BMP file(1). As shown in the community thread, when users provide their BMP splash screen image, Toradex support can convert it to the proper iMX6 format (*.tss file)(1).
File Requirements
Make sure your BMP file meets these requirements:
  • Format: BMP format (8BPP - 8 bits per pixel)(1)
  • Proper dimensions: Should match your display resolution
Alternative Contact Method
You can use share.toradex.com to upload your BMP file if needed(1).
The conversion from BMZ (used on T20) to the TSS format (required for iMX6) is not something that can be done with publicly available tools - it requires Toradex’s internal conversion process(1).
