Verdin iMX8MP 2GB WB IT V1.1A
Image: torizon-core-docker-verdin-imx8mp-Tezi_6.6.1+build.12
Custom carrier board;
For our project we have two differen SPI busses, which are accessed via SPIDEV driver.
Most of the time everything works as expected, expect with some minor (most likely unrelated) errors.
But sometimes the hardware-pins associated with /dev/spidev1.0 and /dev/spidev2.0 are swapped. Which means after a restart, its possible that /dev/spidev1.0 is associated with ecspi2 and /dev/spidev2.0 is associated with ecspi1.
Restarting the device, fixes this problem. spidev1.0 - ecspi1, spidev2.0 - ecspi2.
Is there a way to make sure spidev1.0 is allways assicated with ecspi1, and the same for spidev2.0?
Or is this a part of the startup process that can’t be fixed?
DeviceTree for the SPIDEV:
Pin-Definitions:
/* Verdin SPI_1 */
&ecspi1 {
#address-cells = <1>;
#size-cells = <0>;
cs-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi1>;
/* Verdin SPI_2 */
&ecspi2 {
#size-cells = <0>;
cs-gpios = <&gpio5 21 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&pinctrl_ecspi2>;
pinctrl_ecspi1: ecspi1grp {
fsl,pins =
<MX8MP_IOMUXC_ECSPI1_MISO__ECSPI1_MISO 0x1c4>, /* SODIMM 198 */
<MX8MP_IOMUXC_ECSPI1_MOSI__ECSPI1_MOSI 0x4>, /* SODIMM 200 */
<MX8MP_IOMUXC_ECSPI1_SCLK__ECSPI1_SCLK 0x4>, /* SODIMM 196 */
<MX8MP_IOMUXC_ECSPI1_SS0__GPIO5_IO09 0x1c4>; /* SODIMM 202 */
pinctrl_ecspi2: ecspi2grp {
fsl,pins =
<MX8MP_IOMUXC_I2C4_SCL__ECSPI2_MISO 0x1c4>, /* SODIMM 14 */
<MX8MP_IOMUXC_I2C3_SDA__ECSPI2_MOSI 0x4>, /* SODIMM 93 */
<MX8MP_IOMUXC_I2C3_SCL__ECSPI2_SCLK 0x4>, /* SODIMM 95 */
<MX8MP_IOMUXC_I2C4_SDA__GPIO5_IO21 0x1c4>; /* SODIMM 12 */
Activation of the spidev-driver:
/* Verdin SPI_1 */
&ecspi1 {
#size-cells = <0>;
spidev@0 {
/* Use compatible "rohm,dh2228fv" to bind spidev driver */
compatible = "rohm,dh2228fv";
reg = <0>;
spi-max-frequency = <10000000>;
/* Verdin SPI_2 */
&ecspi2 {
#size-cells = <0>;
spidev@0 {
reg = <0>;
gpioinfo output in case of swapped SPIs:
gpiochip4 - 32 lines:
line 0: "SODIMM_42" unused input active-high
line 1: "SODIMM_46" unused input active-high
line 2: "SODIMM_187" unused input active-high
line 3: "SODIMM_20" unused input active-high
line 4: "SODIMM_22" unused input active-high
line 5: "SODIMM_15" "KEY0" input active-high [used]
line 6: "SODIMM_196" unused input active-high
line 7: "SODIMM_200" unused input active-high
line 8: "SODIMM_198" unused input active-high
line 9: "SODIMM_202" "spi2 CS0" output active-low [used]
line 10: unnamed unused input active-high
line 11: unnamed unused input active-high
line 12: unnamed unused input active-high
line 13: unnamed unused input active-high
line 14: unnamed "scl" output active-high [used open-drain]
line 15: unnamed "sda" input active-high [used open-drain]
line 16: "SODIMM_55" "KEY4" input active-high [used]
line 17: "SODIMM_53" "KEY3" input active-high [used]
line 18: "SODIMM_95" unused input active-high
line 19: "SODIMM_93" unused input active-high
line 20: "SODIMM_14" unused output active-high
line 21: "SODIMM_12" "spi1 CS0" output active-low [used]
line 22: "SODIMM_129" unused input active-high
line 23: "SODIMM_131" unused input active-high
line 24: "SODIMM_137" unused input active-high
line 25: "SODIMM_139" unused input active-high
line 26: "SODIMM_147" unused input active-high
line 27: "SODIMM_149" unused input active-high
line 28: "SODIMM_151" unused input active-high
line 29: "SODIMM_153" unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
gpioinfo while the SPIs are initalised as expected:
line 5: "SODIMM_15" unused input active-high
line 9: "SODIMM_202" "spi1 CS0" output active-low [used]
line 16: "SODIMM_55" unused input active-high
line 17: "SODIMM_53" unused input active-high
line 21: "SODIMM_12" "spi2 CS0" output active-low [used]
