I understand you’re exploring SPI communication using the spidev library on a Toradex iMX7 Colibri board and have questions about chip select management and data transmission.
Regarding the necessity of toggling the chip select (CS) line, it is generally required for correct data transmission over SPI. The CS line is used to signal the beginning and end of a data frame, ensuring that the peripheral device knows when to listen and when to ignore the bus. Most SPI peripherals require the CS line to be pulled low at the start of the transaction and set high at the end. However, the spidev library and your SPI device’s driver might manage this for you automatically when you use the xfer() or xfer2() methods, depending on how the SPI bus is configured in your device tree or SPI setup. It’s important to consult your specific SPI device’s datasheet for its CS handling requirements.
For sending an array of data using the spidev library, your approach using the spi.xfer() method is correct. This method allows you to send and receive data in a full-duplex manner. The data to be sent is passed as a list or array, and the method returns a list of the same length containing the data received during the transaction. Your example code correctly demonstrates setting up the SPI device, configuring its parameters, and preparing a buffer for transmission. When using spi.xfer(xfrbuf), the xfrbuf array is sent out over SPI, and the response from the SPI device is captured in the response variable.
Here’s a simplified example of sending an array of data and receiving the response:
import spidev
# SPI setup
spi = spidev.SpiDev()
spi.open(2, 0) # Open SPI bus 2, device 0
spi.max_speed_hz = 1000000
spi.mode = 3
# Data to send
data_to_send = [0x01, 0x02, 0x03, 0x04] # Example data
# Transmit data and receive response
response = spi.xfer(data_to_send)
print("Response: ", response)
In this example, data_to_send is an array of bytes to be transmitted. The spi.xfer() method sends this data and captures the response from the SPI device in the response variable.
Remember, the effectiveness of your SPI communication
SPI (Linux) | Toradex Developer Center.
How did you like my response?
