Hello everyone!
I’m currently exploring EtherCAT communication on the Toradex IMX7 Colibri evaluation board using the spidev
library. I have a query regarding the necessity of managing the chip select (CS) line while transmitting data over SPI.
Is it mandatory to toggle the chip select line high and low for correct data transmission? Additionally, I’m seeking guidance on how to effectively send an array of data using the spidev
library.
For instance, I’m considering using the spi.xfer()
method for data transmission. Could someone provide insights on the proper usage of this method to send data arrays over SPI?
Your assistance and expertise are greatly appreciated!
Thank you."
Example format (which i using currently):
SPI setup
spi = spidev.SpiDev()
spi.open(2, 0) # Assuming SPI bus 0, device 0
spi.max_speed_hz = 1000000 # Adjust as needed
spi.mode = 3
def Etc_Read_Reg(address, length):
Result = ULONG() # Initialize Result as ULONG instance
Addr = UWORD() # Initialize Addr as UWORD instance and set address
xfrbuf = (ctypes.c_uint8 * 7)() # Create buffer for SPI transfer
Addr.LANWord = address
xfrbuf[0] = COMM_SPI_READ # SPI read command
xfrbuf[1] = Addr.LANByte[1] # Address high byte
xfrbuf[2] = Addr.LANByte[0] # Address low byte
print()
print("Entered Read_reg")
print()
print("xfrbuf before filling: ", end="")
for i in range(3):
print("{:02X} ".format(xfrbuf[i]), end="")
for i in range(length):
xfrbuf[i + 3] = DUMMY_BYTE # Fill dummy bytes after address bytes
print("\nxfrbuf after filling: ", end="")
for i in range(7):
response = spi.xfer(xfrbuf)
# response = spi.xfer2(list(xfrbuf)) # Perform SPI transfer and receive response
Result.LANByte[i] = response[i + 3] # Assign received bytes to Result.LANByte[i]
return Result.LANLong
