My specs first:
Module: Colibri iMX6DL 512 MB IT v1.1B
Carrier: Colibri Evaluation Board
OS : TorizonCore Upstream 5.6.0 devel_202202+build.21
Docker: Docker Desktop 4.5.1 (74721) is currently the newest version available.
VSC: Version 1.65.2
Hello!
I am cross-compiling code to my target from a windows laptop running VSC. I am trying to debug my SPI interface, which seems to be mostly working from what I can see so far, (aside from some minor issues I want to debug)
My SPI is based entirely from the example code spidev_test.c found here:
with very little modification.
I can reliably get the program to run when I create the executable (on my target, an ARM 32-bit processor on the: Colibri iMX6DL 512MB IT module running on a carrier board: Toradex Colibri Evaluation Board) and run it from the command line prompt.
However, when I run it using the debugger, it aborts on the line indicated below.
The debugger inspects the value of device to be “/dev/spidev3.0” as it should be, but the 0_RDWR does not seem to evaluate to anything… although this might be #defined (can you inspect a #defined value with the debugger?)
parse_opts(argc, argv);
if (input_tx && input_file)
pabort("ERROR 220: only one of -p and --input may be selected");
fileDescriptor = open(device, O_RDWR); // returns -1
if (fileDescriptor < 0)
pabort("ERROR 221: SPI can't open SPI device"); // exits the program inside this function
I am wondering if there is something I am doing wrong… I am new to VSC so any of the .json properties may be wrong…
launch.json
"version": "0.2.0",
"configurations": [
"name": "C++ Launch",
"type": "cppdbg",
"request": "launch",
"program": "${workspaceRoot}\\EmeraBlockEnergyBox",
"args": [
"-I", "5000",
"-s", "50",
"-v"
"miDebuggerServerAddress": "",
"stopAtEntry": false,
"cwd": "${workspaceRoot}",
"externalConsole": false,
"MIMode": "gdb",
"miDebuggerPath": "gdb-multiarch",
"targetArchitecture": "",
"preLaunchTask": "${defaultBuildTask}",
"setupCommands": [
"description": "Setting architecture",
"text": "set architecture %{torizon.gdb-arch}",
"ignoreFailures": false,
"externalConsole":false
settings.json
"torizon.configuration": "debug",
"torizon.appfolder": "appconfig_0",
"files.associations": {
"numeric": "c",
"stdlib.h": "c",
"emerablockenergybox.h": "c",
"spidev.h": "c",
"cstdio": "c"
tasks.json
"version": "2.0.0",
"tasks": [
"label": "build_debug",
"command": "make",
"type": "shell",
"args": [],
"problemMatcher": {
"base": "$gcc"
"options": {
"env": {
"CFLAGS": "-g",
"CXXFLAGS": "-g"
"group": {
"kind": "build",
"isDefault": true
"label": "build_release",
"command": "make",
"type": "shell",
"args": [],
"problemMatcher": {
"base": "$gcc"
"options": {
"env": {
"CFLAGS": ""
"group": "build"
"label": "clean",
"command": "make",
"type": "shell",
"args": [
"clean"
"problemMatcher": {
"base": "$gcc"
"group": "build"
"detail": "deploy application to work folder",
"label": "deploy",
"command": "make",
"args": [
"WORKDIR=${command:torizon.ccpp.getTargetFolder}",
"install"
"type": "shell",
"group": "none"
"options": {
"env": {
"TORIZON_PROP_ARG": "ARG SSHUSERNAME=#%application.username%#\n"
devcontainer.json
"name": "torizon_EmeraBlockEnergyBox",
"dockerFile": "Dockerfile",
"extensions": [
"ms-vscode.cpptools"
"containerEnv": {
"AR": "arm-linux-gnueabihf-ar",
"AS": "arm-linux-gnueabihf-as",
"CC": "arm-linux-gnueabihf-gcc",
"CXX": "arm-linux-gnueabihf-g++",
"CPP": "arm-linux-gnueabihf-cpp",
"LD": "arm-linux-gnueabihf-ld",
"STRIP": "arm-linux-gnueabihf-strip",
"CROSS_COMPILE": "arm-linux-gnueabihf-"
"runArgs": [
"--network=host"
"remoteUser": "torizon",
"postCreateCommand": "mkdir -p /home/torizon/.vscode-server-insiders/extensions ; mkdir -p /home/torizon/.vscode-server/extensions; ln -s /home/torizon/.torizon-extension /home/torizon/.vscode-server-insiders/extensions/toradex.torizon ; ln -s /home/torizon/.torizon-extension /home/torizon/.vscode-server/extensions/toradex.torizon ; chgrp docker /var/run/docker.sock ; true",
"mounts": [
"source=${localEnv:HOME}${localEnv:USERPROFILE}/.moses,target=/home/torizon/.moses,type=bind",
"source=//var/run/docker.sock,target=/var/run/docker.sock,type=bind",
"source=c:\\Users\\LeighBoyd\\.vscode\\extensions\\toradex.torizon-1.3.0,target=/home/torizon/.torizon-extension,type=bind"
Any ideas what I can try to make it work in debug mode?
