Hi Toradex,
please help me to configure SPI as a slave on Colibri-IMX6ULL.
and i am using -
- Colibri-IMX6ULL 512MB IT
- iris-v2-carrier board
- linux platform
Thanks & regards,
Manohara
Hi Toradex,
and i am using -
Thanks & regards,
Manohara
Hi Manohara,
Configuring the SPI interface as a slave on the Colibri iMX6ULL module involves several steps, including modifying the device tree and ensuring the correct kernel configuration. Here’s a step-by-step guide to help you:
Device Tree Modification:
arch/arm/boot/dts/ directory of the kernel source.&ecspi1 {
spi-slave;
/* other configurations */
spi-slave property to the SPI node to configure it as a slave.Kernel Configuration:
make menuconfig in the kernel source directory and navigating to:Device Drivers -> SPI support -> User mode SPI device driver support
Recompile the Device Tree and Kernel:
Testing:
dtc tool or by inspecting the /proc/device-tree directory.User-Space Access:
spidev driver is enabled and the corresponding device files (e.g., /dev/spidevX.Y) are available.Please note that configuring SPI as a slave might require additional considerations depending on your specific use case and the peripheral devices you are interfacing with.
Toradex AI Assistant
Hi @Manohara,
We have replied to you on your other ticket. Please continue there itself.
