Running uuu from Debian
I’ve tried running the uuu version from Debian, which works just fine. Tested with a Verdin IMX8MP on a dev board.
To check whether it recognizes your board (after forcing it into recovery mode), you can use:
uuu -lsusb
Then to actually run through the recovery process, run the following (from inside the unpacked recovery zipfile). This replaces the recover-linux.sh script from the instructions.
uuu recovery
In this command, recovery points to the directory by that name, and instructs uuu to run commands from the recovery/uuu.auto file and run them.
Running without root
As I expected, the recovery can run without root with some udev rules. The uuu tool contains the needed rules and instructions on how to install them, you can get these instructions by running:
uuu -udev
Note that recent versions of the uuu Debian package (since 1.5.21-2) already contain the udev rules generated by the above command, so you can skip this step (but read on for more).
However, the rules generated by this command are not complete, at least not for the Verdin board. During the recovery, it seems the uuu.auto config instructs uuu to upload a fastboot-compatible bootloader and run it, which uses different USB ids than what uuu normally uses. Based on the IDs listed in the uuu.auto file, combined with uuu -udev output, I am now using the below udev file which allows running uuu without root.
cat /etc/udev/rules.d/70-local-toradex-recovery.rules
# These were generated by uuu -udev
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="012f", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="0129", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="0147", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="15a2", ATTRS{idProduct}=="004f", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="013e", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="0146", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="014a", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="014b", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="15a2", ATTRS{idProduct}=="0076", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="15a2", ATTRS{idProduct}=="0054", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="15a2", ATTRS{idProduct}=="0061", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="15a2", ATTRS{idProduct}=="0063", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="15a2", ATTRS{idProduct}=="0071", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="15a2", ATTRS{idProduct}=="007d", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="15a2", ATTRS{idProduct}=="0080", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="0128", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="0126", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="0135", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="0134", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="012b", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="b4a4", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="0151", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="3016", ATTRS{idProduct}=="1001", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="066f", ATTRS{idProduct}=="9afe", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="066f", ATTRS{idProduct}=="9bff", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="0153", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="a4a5", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="18d1", ATTRS{idProduct}=="0d02", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="3016", ATTRS{idProduct}=="0001", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1fc9", ATTRS{idProduct}=="0152", TAG+="uaccess"
# These were manually created based on the Tezi (Toradex easy installer)
# `recovery/uuu.auto` config file, which lists a number of ids that are used by
# a second stage fastboot bootloader.
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="0152", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="4000", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="403a", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="403d", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="403f", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="4040", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="4041", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="4042", TAG+="uaccess"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="4046", TAG+="uaccess"
