Source code for camera control (analogue or usb)
I would like to know if you have sample source code in C# to control an usb or analogue camera in my own program. I search on documentation pages but I did not find it. Is it possible to have that ? thanks in advance.
@aekhi,
We don’t have C# sample code. Please help yourself to get it on the google search.
We have shared native application source code in below links
https://developer.toradex.com/knowledge-base/usb-webcam-for-windows-ce
https://developer.toradex.com/software/windows-embedded-compact/toradex-ce-libraries-and-code-samples#Sample_codes
Thank you for understanding.
As Raja said, we don’t have C# sample code available.
In addition to the links he provided, you can have a look at:
Here you can find some sample (native) code that you can use to access the imx6 camera interface.
If you need to use that from C# my suggestion is to wrap the native code inside a DLL that you can then call from your managed app.
If you want to do some kind of image processing, probably going fully native is the best option for performances.
