We made ourselves a custom carrier board. The project is focused on a in vitro diagnosis machine, with a display, camera, some LED drivers, USBs and a BMS. Other SOMs are working normally, but for any particular reasons, we have two which can’t be considered working.
The SOMs are: Verdin i.MX8MP Q 8GB WB IT, V1.1A, PN1: 15629424, PN2: 15629369
- PN1: 15629424
It can boot normally into the main app, or it can reset, and after 8 attempts the module shuts down the 3.3V rail and itself. The behavior is not deterministic.
U-Boot SPL 2022.04-6.6.0-devel+git.d262075124dc (Mar 08 2024 - 14:27:40 +0000)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
DDR configured as dual rank
SEC0: RNG instantiated
Normal Boot
WDT: Started watchdog@30280000 with servicing (60s timeout)
Trying to boot from BOOTROM
Boot Stage: Primary boot
Find img info 0x&4802a600, size 888
Need continue download 1024
Normal Boot
Normal Boot
Normal Boot
Normal Boot
Normal Boot
Normal Boot
Normal Boot
2) PN2: 15629369
The module shuts doesn’t get past the following message and shuts down after it.
Normal Boot
Both module work by getting into EasyInstaller. We upload the desired image with an USB stick. The EasyInstaller Version “Verdin-iMX8MP_ToradexEasyInstaller_5.7.6+build.21” works with the USB stick.
I can provide the schematics for the carrier board if you need them, but keep in mind that we normally have working SOMs.
Thank you for your help!
