My Application is on Video Processing. I need to run a specific video in which i need to track the centroid, a reticule pointing the centre and to form a trajectory of centroid.
Which software should i install to run opencv cpp
hi @hemasree
Could you provide the version of the Hardware and Software of your module? Which carrier board are you using?
How are you running this video?
You may install Bsp 2.8.
