hello sir
i am trying to run snmp server(snmpd) on imx6 . I am using lxde image for it. I ahve included net-snmp in local.conf and build sdk. then installed in board.
snmptrap working fine. but snmpget or snmpwalk on localhost is not working.
As per my knowledge snmpd is required to run these command.
Kindly help to resolve the issuelink text
Hi
Sounds reasonable. So did you install the server package as well? E.g. did you add net-snmp-server to your image?
Max
P.S. Note that copy / past text from console output is prefered over sending screenshots.
thanks Mr. Max
I have added net-snmp-server and all is working good.
thanks for support
