However, the latest Torizon 7.7.0 did not worked. Below is the output from debug port. It stopped after loading OS and reboot.
U-Boot SPL 2024.04-7.8.0-devel+git.b7c747d8c084 (Sep 04 2026 - 16:19:18 +0000)
SOC: 0xb0009500
LC: 0x40010
Trying to boot from USB SDP
Failed to configure default pinctrl
UID: 80bd9ddb0a344f3cab420f67f2c030ce
SDP: initialize…
SDP: handle requests…
Downloading file of size 1644544 to 0x90400000… done
Jumping to header at 0x90400000
Header Tag is not an IMX image
Found header at 0x90400000
NOTICE: BL31: v2.10.0 (release):lf-6.6.52-2.2.1-dirty
NOTICE: BL31: Built : 06:40:36, Jul 7 2025
U-Boot 2024.04-7.8.0-devel+git.b7c747d8c084 (Sep 04 2026 - 16:19:18 +0000)
CPU: i.MX95 rev2.0 at 1800MHz
CPU: Industrial temperature grade (-40C to 105C) at 42C
LM Boot reason: por, origin: -1, errid: -1
LM shutdown reason: por, origin: -1, errid: -1
DRAM: 7.8 GiB
Core: 319 devices, 32 uclasses, devicetree: separate
Loading Environment from nowhere… OK
In: serial
Out: serial
Err: serial
Model: Toradex 0096 SMARC iMX95 Hexa 8GB WB IT V1.2B
Serial#: 08968038
BuildInfo:
- SM firmware Build 571, Commit f0911787, Sep 14 2026 22:53:19
- ELE firmware version 2.0.5-fe6641ef
Detect USB boot. Will enter fastboot mode!
Net: WARNING: no MAC address assigned for MAC0
imx_get_mac_from_fuse: fuse read err: 0
eth0: enetc-0 [PRIME]WARNING: no MAC address assigned for MAC1
, eth1: enetc-1WARNING: no MAC address assigned for MAC2
Warning: enetc-2 (eth2) using random MAC address - de:39:c4:11:6a:ac
, eth2: enetc-2
Fastboot: Normal
Boot from USB for uuu
Starting download of 2248 bytes
downloading of 2248 bytes finished
Starting download of 209 bytes
downloading of 209 bytes finished
Starting download of 40022487 bytes
downloading of 40022487 bytes finished
Executing script at 9c600000
Bootargs: video=DP-1:1280x720@60D console=ttyLP1,115200 quiet rootfstype=squashfs root=/dev/ram autoinstall
Loading kernel from FIT Image at 90400000 …
Using ‘conf-freescale_imx95-toradex-smarc-dev.dtb’ configuration
Trying ‘kernel-1’ kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x904000fc
Data Size: 7830659 Bytes = 7.5 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x94400000
Entry Point: 0x94400000
Hash algo: sha256
Hash value: 721c9160f899f58db0de3bf2490b2827683cad271e630c7df338965ce420a2fd
Verifying Hash Integrity … sha256+ OK
Loading ramdisk from FIT Image at 90400000 …
Trying ‘ramdisk-1’ ramdisk subimage
Description: tezi-initramfs
Type: RAMDisk Image
Compression: uncompressed
Data Start: 0x90b9cfd4
Data Size: 32034816 Bytes = 30.6 MiB
OS: Linux
Load Address: 0x9e800000
Entry Point: unavailable
Hash algo: sha256
Hash value: 0f5bafd1cdf2fe2c82e9cc687e82f867160b2e315dcd5beadd5fd08e95184f79
Loading ramdisk from 0x90b9cfd4 to 0x9e800000
Loading fdt from FIT Image at 90400000 …
Trying ‘fdt-freescale_imx95-toradex-smarc-dev.dtb’ fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x90b77ea8
Data Size: 101636 Bytes = 99.3 KiB
Load Address: 0x9c400000
Hash algo: sha256
Hash value: ea9d71b21c7dadfc003a6a9f149049788c800deb4531e502596c15ed6a9f640b
Loading fdt from 0x90b77ea8 to 0x9c400000
Using ‘conf-toradex-smarc-imx95_spi0-cs0_spidev_overlay.dtbo’ configuration
Trying ‘fdt-toradex-smarc-imx95_spi0-cs0_spidev_overlay.dtbo’ fdt subimage
Data Start: 0x90b9a2a0
Data Size: 557 Bytes = 557 Bytes
Load Address: 0x9c440000
Hash algo: sha256
Hash value: 1a0d95c31dd950c895689fbac3fd7522afa3f5418a4e417bab1a31ab3d35bcb1
Using ‘conf-toradex-smarc-imx95_spi0-cs1_spidev_overlay.dtbo’ configuration
Trying ‘fdt-toradex-smarc-imx95_spi0-cs1_spidev_overlay.dtbo’ fdt subimage
Data Start: 0x90b9a5e0
Hash algo: sha256
Hash value: adbe8c7b152f096aa3be779abeafb4621496876a9d7c562c9586bb39217d6f7c
Using ‘conf-toradex-smarc-imx95_spi1-cs0_spidev_overlay.dtbo’ configuration
Trying ‘fdt-toradex-smarc-imx95_spi1-cs0_spidev_overlay.dtbo’ fdt subimage
Data Start: 0x90b9a920
Data Size: 530 Bytes = 530 Bytes
Hash algo: sha256
Hash value: ecbb9bd3d53190acbaec1e8ac4c510c70b833cb5feae0050c450e93782ddf333
Using ‘conf-toradex-smarc-imx95_spi1-cs1_spidev_overlay.dtbo’ configuration
Trying ‘fdt-toradex-smarc-imx95_spi1-cs1_spidev_overlay.dtbo’ fdt subimage
Data Start: 0x90b9ac44
Hash algo: sha256
Hash value: 8bbbdabe93075fc9aac41c8b03aff9012ea05b45f785a2294270eafa1d6b3880
Booting using the fdt blob at 0x9c400000
Working FDT set to 9c400000
Uncompressing Kernel Image to 94400000
Loading Ramdisk to fb053000, end fcee0000 … OK
Loading Device Tree to 00000000fb037000, end 00000000fb052e43 … OK
Working FDT set to fb037000
Starting kernel …
[ 0.127677] cpu cpu0: EM: invalid power: 0
[ 0.200222] fsl_enetc_mdio 0003:01:00.0: Cannot get IERB init status: -517
[ 0.200329] pcieport 0003:01:01.0: of_irq_parse_pci: failed with rc=-22
[ 0.268580] rtc-ds1307 3-0032: hctosys: unable to read the hardware clock
[ 0.431350] debugfs: Directory ‘wakeup’ with parent ‘pm_genpd’ already present!
[ 0.438674] debugfs: Directory ‘vpu’ with parent ‘pm_genpd’ already present!
[ 0.445723] debugfs: Directory ‘npu’ with parent ‘pm_genpd’ already present!
[ 0.452763] debugfs: Directory ‘noc’ with parent ‘pm_genpd’ already present!
[ 0.459822] debugfs: Directory ‘m7’ with parent ‘pm_genpd’ already present!
[ 0.466817] debugfs: Directory ‘gpu’ with parent ‘pm_genpd’ already present!
Running /etc/rc.local…
Toradex Easy Installer 7.8.0-devel-20260917+build.611 ()
Starting udev
[ 3.278779] debugfs: File ‘:soc:display-controller@4b400000’ in directory ‘domains’ already present!
[ 3.288028] debugfs: File ‘:soc:display-controller@4b400000’ in directory ‘domains’ already present!
[ 3.859044] mdio_bus 0002:00:10.0-imdio:10: Polling timeout, line: 381
[ 3.875592] fsl_enetc4 0002:00:10.0: cannot create xpcs mdiodev (-19)
[ 3.882275] fsl_enetc4 0002:00:10.0: Failed to create MDIO bus
[ 4.229768] debugfs: File ‘:soc:display-controller@4b400000’ in directory ‘domains’ already present!
[ 4.238930] debugfs: File ‘:soc:display-controller@4b400000’ in directory ‘domains’ already present!
[ 4.435207] imx95-pixel-interleaver 4b0d0000.bridge: Failed to create device link (0x180) with 4b400000.display-controller
[ 4.453647] usbmisc_imx 4c200200.usbmisc: vbus is error
[ 4.458926] usbmisc_imx 4c200200.usbmisc: Error occurs during detection: -22
System time was Thu Jan 1 00:00:05 UTC 1970.
Setting the System Clock using the Hardware Clock as reference…
hwclock: RTC_RD_TIME: Invalid argument
System Clock set. System local time is now Thu Jan 1 00:00:05 UTC 1970.
Fri Mar 9 12:34:56 UTC 2018
Saving the System Clock time to the Hardware Clock…
Hardware Clock updated to Fri Mar 9 12:34:56 UTC 2018.
Welcome to the Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently, the installer
does not have a serial console interface. You can use the Toradex Easy Installer
via any of the available display interfaces using USB mouse/keyboard or via a
network connection using VNC. Use:
ip addr show
to display the Ethernet IP address(es) or use USB NCM at IP 192.168.11.1.
Check our documentation at:
~ # [ 175.393032] reboot: Restarting system
