Hello world,
I’m still developing with my recent Colibri (V1.0A) module on an old evaluation board (V2.1c).
I’m starting working with the CAN bus, and it appears I have two solutions :
- Use the on-module FlexCan and connect the correct pin (on extension header) to the input of the CAN transceiver. I’ll do that later.
- Use the on-board SJA1000 controller which is not supported due to the new SPI controller used (MCP2510). That’s what I’m trying to do.
I have built Linux with can modules. Then I load manually the modules to have the following running modules:
# lsmod
Module Size Used by Not tainted
sja1000_platform 2881 0
sja1000 5439 1 sja1000_platform
can_bcm 11706 0
can_raw 6064 0
can 25548 2 can_bcm,can_raw
can_dev 8509 1 sja1000
But, I still don’t have a can0 interface while typing ip a. Is there an additional module to load to make the interface appearing?
Léo
