Hi all,
I want to develop a VOIP communication for audio communication using Colibri IMX7D . Is the stack readily available , or we need to develop. Any example codes for testing. Please suggest the way to start the Implementation.
Thanks in advance.
To develop a VoIP communication system using the Colibri iMX7D, you will need to implement a SIP (Session Initiation Protocol) stack for handling the signaling and an RTP (Real-time Transport Protocol) stack for the media streaming. Here are some steps and suggestions to get you started:
1. SIP Stack
There are several open-source SIP stacks available that you can use:
- PJSIP: A free and open-source multimedia communication library written in C language, which implements standard-based protocols such as SIP, SDP, RTP, STUN, TURN, and ICE.
- Linphone: An open-source VoIP service that provides a SIP stack and media stack.
2. RTP Stack
For RTP, you can use:
- JRTPLIB: A library that provides support for the Real-time Transport Protocol (RTP) as defined in RFC 3550.
3. Integration with Colibri iMX7D
You will need to cross-compile these libraries for the ARM architecture of the Colibri iMX7D. Here are the general steps:
Prerequisites
- Toolchain: Ensure you have the appropriate cross-compilation toolchain installed.
- Yocto Project: If you are using Yocto, you can create a custom layer and recipes for these libraries.
Steps
Set Up Development Environment:
- Set up your cross-compilation environment.
- Download the source code of the SIP and RTP stacks.
Cross-Compile Libraries:
- Configure and compile the libraries for the ARM architecture.
- For PJSIP, you can follow their cross-compilation guide.
Develop Application:
- Develop your application using the SIP and RTP libraries.
- Implement the necessary signaling and media handling logic.
Testing:
- Test your application on the Colibri iMX7D module.
- Use tools like
sipp
for SIP signaling testing and rtp-tools
for RTP stream testing.
Hi @srinivas3228,
Apart from suggestions from Toradex AI, you may take starting reference from this article
