SIM7600e with Toradex Apalis Imx6q
I got two observation for my simcom module. And I conform I am using old firmware.
By using this firmware I unable to do the SSL/TLS configuration
But, my requirement I want to configure TLS MQTT Server.
And also I got confused with this command,
AT+CMQTTCONNECT=0,“tcp://test.mosquitto.org:1883”,60,1
And I know TLS configuration done once update module firmware,
But, I don’t know, how to configure this following server?
AT+CMQTTCONNECT=0,“tls://xxxx.net:8883”,60,1
But, This is not the proper as per the document CMQTTCONNECT command begin with "tcp://"
Please provide your feedback.
1, Without TLS (old firmware)
toradex_apalis6q:/ # echo -e “ATI\r\n” > /dev/ttyUSB3
Manufacturer: SIMCOM INCORPORATED
Model: SIMCOM_SIM7600E-H
Revision: SIM7600M22_V1.1
IMEI: 867584030013333
+GCAP: +CGSM,+DS,+ES
OK
Document:
https://simcom.ee/documents/SIM7500E/SIM7500_SIM7600%20Series_MQTT_ATC_V1.01.pdf
2. With TLS (new firmware)
Document:
	https://simcom.ee/documents/SIM7X00/SIM7500_SIM7600_SIM7800%20Series_MQTT_AT%20Command%20Manual_V1.00.pdf
Thanks & Regards,
VinothS
HI @vinothS
Could you provide the version of the hardware and software of your module? Which carrier board are you using?
Unfortunately I did not understand your Issue? Could you re-describe it, please?
What is your application? What are you trying to do?
Hi @vinothS, what @jaski.tx meant was the Toradex hardware (module and carrier board) and software versions of things you are talking about.
Please check my response below.
OK
Unfortunately I did not understand your Issue? Could you re-describe it, please? What is your application? What are you trying to do?
I want to implement TLS Server with SIM7600E module, I would like to connect tls(Transport Layer Security) server with sim7600e,
AT+CMQTTCONNECT=0,**tls://**ujet-vehiclesf0a0e.azure-devices.net:8883
But, This is not the proper as per the document CMQTTCONNECT command begin with “tcp://
Application:
For 4G data restrictions. I want to use 4G data for Cloud (Telematic Server (TLS)) access only.In this case we should not share 4G internet to user. we need some fix.
Thanks & Regards,
VinothS
Hi @jaski.tx , I am working on SIM7600E gsm module with Toradex apalis imx6q + Android Nougat
Thanks & Regards,
VinothS
Hi @marcel.tx @jaski.tx .I am working on SIM7600 GSM module with Toradex Apalis Imx6q + Android Nougat. I want to implement MQTT over SIM7600 GSM module.
hi @vinothS
For questions regarding Android, please contact our Partner Kynetics.
Thanks and best regards,
