As suggested by the Toradex support team we bought Sierra EM9291 and use it with Verdin iMX8M on a Mallow board.
The modem is not detected, and dmesg suggests that device enumeration fails (phy link never came up).
Furthermore, on device boot, we observe write timeouts on i2c-3 <i2c_imx_write> write timedout.
Could you please help to clarify whether the modem is supported officially (despite not listed in the compatible peripherals list), or do we need to customize dtb?
I can confirm that the device is indeed operating in PCIE mode (PCIE_DIS=0), in the meantime checking further signals.
Thanks for your help in advance.
[ 10.134324] imx6q-pcie 33800000.pcie: host bridge /soc@0/pcie@33800000 ranges:
[ 10.134374] imx6q-pcie 33800000.pcie: IO 0x001ff80000..0x001ff8ffff -> 0x0000000000
[ 10.134392] imx6q-pcie 33800000.pcie: MEM 0x0018000000..0x001fefffff -> 0x0018000000
[ 10.198409] i2c i2c-3: <i2c_imx_write> write timedout
[ 10.205140] lm75: probe of 3-004f failed with error -110
[ 10.368620] imx6q-pcie 33800000.pcie: iATU: unroll T, 4 ob, 4 ib, align 64K, limit 4G
[ 10.814216] CAN device driver interface
[ 11.360598] imx6q-pcie 33800000.pcie: Phy link never came up
[ 12.070276] Bluetooth: FW download over, size 623352 bytes
[ 12.309331] btmrvl_sdio mmc2:0001:2: sdio device tree data not available
[ 12.348725] imx6q-pcie 33800000.pcie: Phy link never came up
[ 12.349565] imx6q-pcie 33800000.pcie: PCI host bridge to bus 0000:00
[ 12.349583] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 12.349592] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 12.349599] pci_bus 0000:00: root bus resource [mem 0x18000000-0x1fefffff]
Software summary
Bootloader: U-Boot
Kernel version: 6.6.84-7.2.0-g87bfb710b6f1 #1-Torizon SMP PREEMPT Mon Mar 31 08:47:48 UTC 2025
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/bc82c85a12c54eb00
Distro name: NAME="Torizon OS"
Distro version: VERSION_ID=7.2.0-build.13
Distro variant: VARIANT="Docker"
Hostname: verdin-imx8mm-15557745
Hardware info
HW model: Toradex Verdin iMX8M Mini WB on Verdin Development Board
Toradex version: 0060 V1.1C
Serial number: 15557745
Processor arch: aarch64
