I have run a simple test to check the configuration of my SPI (as close to default as possible), and I’m worried by what I see on the signals, in particular SPI_CLK
does not look healthy:
This shows a two byte transaction sending the string {0xFF, 0xAA}.
The top signal (green) is connected to SPI CS
(pin 86), the middle signal (yellow) to SPI CLK
(pin 88), and the bottom (blue) to SPI TXD
(pin 92). I am troubled by the following two details, both affecting the clock:
- The falling edge of
CS
and rising edge ofCLK
are almost synchronous, and it looks as if the hold time for the first data bit is truncated to half a clock cycle. - There is a 60ns clock glitch between the first and second bytes. This is likely to cause my target hardware trouble. (Ok, not a “glitch” as such, but definitely a drastically truncated clock pulse.)
I’m hoping that I’ve simply misconfigured my SPI device, or perhaps am not talking to /dev/spidev1.0
correctly. My device tree is based on vf500-colibri-eval-v3.dts
, with my customisations replacing vf-colibri-eval-v3.dtsi
&dspi1 {
spidev1: spidev@0 {
compatible = "toradex,evalspi";
reg = <0>;
spi-max-frequency = <10000000>; /* 10 MHz */
and my test code is the following:
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/spi/spidev.h>
int main(int argc, char *argv[])
char data[] = { 0x55, 0xAA };
struct spi_ioc_transfer command = {
.tx_buf = (intptr_t) data,
.len = 2,
int dev = open("/dev/spidev1.0", O_RDWR);
ioctl(dev, SPI_IOC_MESSAGE(1), &command);
close(dev);
return 0;
P.S. I’ve realised that my data clock is only running at 400kHz! Is this the highest available speed under 10MHz for this device?
