I try to set up and test uart-6 (Toradex UART-D) on the Colibri eval board. The UART RX and TX pins (SODIMM pin 75 and 96) are brought out on to the camera interface header (but they don’t appear to be initialized in the device tree).
I add the following to the board level device tree file:
&uart6 {
/* pinctrl-names = "default";*/
pinctrl-0 = <&pinctrl_uart6>;
fsl,dte-mode;
&iomuxc {
imx6ull-colibri {
pinctrl_uart6: uart6-grp {
fsl,pins = <
MX6UL_PAD_CSI_MCLK__UART6_DTE_RX 0x1b0b1
MX6UL_PAD_CSI_PIXCLK__UART6_DTE_TX 0x1b0b1
There are two problems:
- I have to patch out pinctrl-names = “default” in &uart6 otherwise ttymxc5 does not show up in /dev.
- The UART does not work. There is no uart data in or out. the TX/RX pins stay logic low (should be high when idle for UART pins)
Is there anything I am missing?
