Goal
I am trying configure a RGMII PHY as second ethernet on Colibri iMX7 eMMC 1GB.
We have wired a Micrel KSZ9031RNX chip on RGMII signals as the second ethernet based module datasheet:
We want to use this PHY as 1 Gigabit second ethernet along with the original 10/100 ethernet.
What I have tried
I have made the following changes in the device-tree to configure second fec with RGMII signals:
- Adding configs for
fec2based on imx7d-cl-som-imx7.dts. - Adding a
mdiosub-node infec1and settingphy-handleproperty infec1andfec2accordingly. - Removing related pins from pinctrl_gpioX to avoid registering them as GPIO.
- Adding
pinctrl_enet2pinctrl group based on imx7d-cl-som-imx7.dts
Here is the changes in the device-tree:
diff --git a/arch/arm/boot/dts/imx7-colibri.dtsi b/arch/arm/boot/dts/imx7-colibri.dtsi
index 28e7e97..8c53f56 100644
--- a/arch/arm/boot/dts/imx7-colibri.dtsi
+++ b/arch/arm/boot/dts/imx7-colibri.dtsi
@@ -127,6 +127,34 @@
phy-mode = "rmii";
phy-supply = <®_LDO1>;
fsl,magic-packet;
+ phy-handle = <ðphy0>;
+ mdio {
+ #address-cells = <1>;
+ #size-cells = <0>;
+ ethphy0: ethernet-phy@0 {
+ reg = <0>;
+ ethphy1: ethernet-phy@1 {
+ reg = <1>;
+&fec2 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_enet2>;
+ assigned-clocks = <&clks IMX7D_ENET2_TIME_ROOT_SRC>,
+ <&clks IMX7D_ENET2_TIME_ROOT_CLK>;
+ assigned-clock-parents = <&clks IMX7D_PLL_ENET_MAIN_100M_CLK>;
+ assigned-clock-rates = <0>, <100000000>;
+ phy-mode = "rgmii";
+ phy-handle = <ðphy1>;
+ fsl,magic-packet;
+ status = "okay";
&gpmi {
@@ -342,7 +370,7 @@
&iomuxc {
- pinctrl-0 = <&pinctrl_gpio1 &pinctrl_gpio2 &pinctrl_gpio3 &pinctrl_gpio4 &pinctrl_gpio5>;
+ pinctrl-0 = <&pinctrl_gpio1 &pinctrl_gpio2 &pinctrl_gpio3 &pinctrl_gpio5>;
pinctrl_gpio1: gpio1-grp {
fsl,pins = <
@@ -363,27 +391,15 @@
MX7D_PAD_EPDC_DATA05__GPIO2_IO5 0x14 /* SODIMM 121 */
MX7D_PAD_EPDC_DATA06__GPIO2_IO6 0x14 /* SODIMM 123 */
MX7D_PAD_EPDC_DATA07__GPIO2_IO7 0x14 /* SODIMM 125 */
- MX7D_PAD_EPDC_SDCE2__GPIO2_IO22 0x14 /* SODIMM 127 */
MX7D_PAD_UART3_RTS_B__GPIO4_IO6 0x14 /* SODIMM 131 */
- MX7D_PAD_EPDC_GDRL__GPIO2_IO26 0x14 /* SODIMM 133 */
MX7D_PAD_SAI1_RX_DATA__GPIO6_IO12 0x14 /* SODIMM 169 */
MX7D_PAD_SAI1_RX_BCLK__GPIO6_IO17 0x14 /* SODIMM 24 */
MX7D_PAD_SD2_DATA2__GPIO5_IO16 0x14 /* SODIMM 100 */
MX7D_PAD_SD2_DATA3__GPIO5_IO17 0x14 /* SODIMM 102 */
- MX7D_PAD_EPDC_GDSP__GPIO2_IO27 0x14 /* SODIMM 104 */
MX7D_PAD_EPDC_BDR1__GPIO2_IO29 0x14 /* SODIMM 110 */
MX7D_PAD_EPDC_PWR_COM__GPIO2_IO30 0x14 /* SODIMM 112 */
- MX7D_PAD_EPDC_SDCLK__GPIO2_IO16 0x14 /* SODIMM 114 */
- MX7D_PAD_EPDC_SDLE__GPIO2_IO17 0x14 /* SODIMM 116 */
- MX7D_PAD_EPDC_SDOE__GPIO2_IO18 0x14 /* SODIMM 118 */
- MX7D_PAD_EPDC_SDSHR__GPIO2_IO19 0x14 /* SODIMM 120 */
- MX7D_PAD_EPDC_SDCE0__GPIO2_IO20 0x14 /* SODIMM 122 */
- MX7D_PAD_EPDC_SDCE1__GPIO2_IO21 0x14 /* SODIMM 124 */
MX7D_PAD_EPDC_DATA14__GPIO2_IO14 0x14 /* SODIMM 126 */
MX7D_PAD_EPDC_PWR_STAT__GPIO2_IO31 0x14 /* SODIMM 128 */
- MX7D_PAD_EPDC_SDCE3__GPIO2_IO23 0x14 /* SODIMM 130 */
- MX7D_PAD_EPDC_GDCLK__GPIO2_IO24 0x14 /* SODIMM 132 */
- MX7D_PAD_EPDC_GDOE__GPIO2_IO25 0x14 /* SODIMM 134 */
MX7D_PAD_EPDC_DATA12__GPIO2_IO12 0x14 /* SODIMM 150 */
MX7D_PAD_EPDC_DATA11__GPIO2_IO11 0x14 /* SODIMM 152 */
MX7D_PAD_SD2_CLK__GPIO5_IO12 0x14 /* SODIMM 184 */
@@ -467,6 +483,23 @@
+ pinctrl_enet2: enet2grp {
+ fsl,pins = <
+ MX7D_PAD_EPDC_GDSP__ENET2_RGMII_TXC 0x1
+ MX7D_PAD_EPDC_SDCE2__ENET2_RGMII_TD0 0x1
+ MX7D_PAD_EPDC_SDCE3__ENET2_RGMII_TD1 0x1
+ MX7D_PAD_EPDC_GDCLK__ENET2_RGMII_TD2 0x1
+ MX7D_PAD_EPDC_GDOE__ENET2_RGMII_TD3 0x1
+ MX7D_PAD_EPDC_GDRL__ENET2_RGMII_TX_CTL 0x1
+ MX7D_PAD_EPDC_SDCE1__ENET2_RGMII_RXC 0x1
+ MX7D_PAD_EPDC_SDCLK__ENET2_RGMII_RD0 0x1
+ MX7D_PAD_EPDC_SDLE__ENET2_RGMII_RD1 0x1
+ MX7D_PAD_EPDC_SDOE__ENET2_RGMII_RD2 0x1
+ MX7D_PAD_EPDC_SDSHR__ENET2_RGMII_RD3 0x1
+ MX7D_PAD_EPDC_SDCE0__ENET2_RGMII_RX_CTL 0x1
pinctrl_enet1_sleep: enet1sleepgrp {
fsl,pins = <
MX7D_PAD_ENET1_RGMII_RX_CTL__GPIO7_IO4 0x0
Problem
During boot, the second PHY isn’t correctly recognized. Here is the relevant lines (full boot log can be found at very below):
libphy: fec_enet_mii_bus: probed
fec 30be0000.ethernet eth0: registered PHC device 0
30bf0000.ethernet supply phy not found, using dummy regulator
pps pps1: new PPS source ptp1
fec 30bf0000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
fec 30bf0000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: e2:31:b0:bf:41:a5
fec 30bf0000.ethernet eth1: registered PHC device 1
Also strangely, after the boot two ethernet adapters are registered, both referencing the same fec (30bf0000):
Micrel KSZ8041 30be0000.ethernet-1:00: attached PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=30be0000.ethernet-1:00, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Micrel KSZ8041 30be0000.ethernet-1:01: attached PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=30be0000.ethernet-1:01, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
fec 30bf0000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx
IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
fec 30be0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Questions
- Is my changes in device-tree sensible for configuring a RGMII as second PHY on Colibri iMX7 1GB?
- Specifically, I am not sure about the clocking configurations for
fec2. I have noticed the Colibri clocking forfec1is a little bit different than mainline clocking for imx7d. Maybe that should be done forfec2too? - Is the pin bitmasks for
pinctrl_enet2correct (0x1)? Or I should use a different bitmask (possibly a value of 0x73 likepinctrl_enet1pins)? - Is adding
mdiosubnode really necessary? - Why two ethernet adapters are registered after boot? I expected no
eth1to be registered due to failure in registering second PHY. I can confirm both are onfec0as they both are referencing 30bf0000 and aifconfig eth1 downputseth0down too. - What other configurations should we try if the DTS seems correct?
Here is the full boot log: Bootlog with fec2
Here is the full boot log before above changes in DTS: Bootlog without fec2
