Setting timezone Torizon
I need a way to add/configure the timezone. I am aware that no timezone databases are installed in demo images. Will the Torizon release include them?
Hi @jaimeibk,
Could you share your use case? Are you using Torizon without containers? Usually applications in Torizon are in containers and so you set the timezone during docker build on Dockerfile.
Matheus
