Setting alsamixer setting permanently
I have set audio setting using alsamixer command but after reboot setting get lost, so how to set volume setting permanently so that even after reboot it will not change.
Can you try by running
alsactl store
after selecting the settings. This should store the setting in /var/lib/alsa/asound.state.
From alsactl help option
<snip>
Available commands:
  store     <card>  save current driver setup for one or each soundcards
                      to configuration file
  restore   <card>  load current driver setup for one or each soundcards
                      from configuration file
  nrestore  <card>  like restore, but notify the daemon to rescan soundcards
  init      <card>  initialize driver to a default state
  daemon    <card>  store state periodically for one or each soundcards
  rdaemon   <card>  like daemon but do the state restore at first
  kill      <cmd>   notify daemon to quit, rescan or save_and_quit
  monitor   <card>  monitor control events
Also please confirm the module and Linux BSP version you use.
after running alsactl store command i got following message
alsactl: get_control:256: Cannot read control ‘3,0,0,IEC958 Capture Default,0’: Resource temporarily unavailable
Please confirm the module and Linux BSP version you use.
