Set persistent scaling governor performance
Ticket#2021032910000098
Hi, guys.
I need a help with set persistent scaling governor performance.
echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu5/cpufreq/scaling_governor
Where can I put this code to always be retentive or change when starting? It also requirement whenever you are a su user and should be done outside the container. Can you help me with this?
Italo
Hi @italoaugustoandrade ,
One alternative should be creating a systemd service, please check the information provided on this article.
Daniel Morais
Hi @italoaugustoandrade,
I did this by mapping the exact folder into the container. This means you have a small amount of the host made available there which I think should be fine:
You can then access them from your code, I’m in Python.
with open('/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor', 'rt') as fp:
            current_governors['cpu0'] = fp.readline()
Happy to have better suggestions but this seems to work ok for me.
Thanks for your Input.
