Is there a way to set patch_ddr_size
from Linux afterwards, not from the U-Boot.
Basically I don’t have access to the serial port, I just have access to USB or ethernet.
Thanks for your time.
hi @mthpvg
Why do you need to run this from Linux? In our regular images, when uboot is updated then the command is launched automatically.
How did you install/update the image if you don’t have uart connection? Do you have a display connected to the viola Board?
Best regards, Jaski
Hi @jaski.tx,
We use an old uboot from 2.6 and we use the serial/uart to flash the colibri.
Usually we do patch_ddr_size; mmc partconf 0 1 1 0; reset
but this step was missing in some of our products. Now the Colibri is sealed inside a box with no access to the serial port but with access to a USB port that can also be used for ethernet.
We never integrated the patch_ddr_size
functionality outside of U-Boot. Nowadays, we anyway use SPL to achieve the same so we have definitely no plans to ever work on patch_ddr_size
again. That said, you may just set e.g. bootcmd
to do your patch_ddr_size
using fw_setenv from Linux user space and reboot. Just make sure after patch_ddr_size
you set your bootcmd
back to your regular one.
Thanks @marcel.tx. Out of curiosity what would happen if patch_ddr_size
was invoked on each boot?
Out of curiosity what would happen if patch_ddr_size was invoked on each boot?
I believe other than a few wasted CPU cycles upon boot increasing boot time of course nothing bad should happen but let me quickly check…
Yes, patch_ddr_size will just not find the 32-bit memory width value and therefore nothing gets written upon subsequent invocations.
Good to know, thanks.
I’m stunned by the quality of the answers one can get on this website :).
For those interested, in user space we did:
fw_setenv bootcmd
Check that bootcmd
is gone with: fw_printenv
If you still see bootcmd
, re-run: fw_setenv bootcmd
(strangely, we had two bootcmd
Finally:
fw_setenv bootcmd 'patch_ddr_size; env default -a; saveenv; reset'
reboot
This new bootcmd
will:
patch_ddr_size
bootcmd
with theThe trick is that the bootcmd
is back to its default value. We left no trace.
Perfect, thanks for sharing!
