Set MX6QDL_PAD_GPIO_19__GPIO4_IO05 as CLOCK in DEVICE TREE
Hi, I have to configure Colibri MX6QDL_PAD_GPIO_19__GPIO4_IO05 control signals as CLOCK.
In device-tree I see the signal as GPIO in the node “pinctrl_weim_gpio_3”. I can change the muxing with MX6QDL_PAD_GPIO_19__CCM_CLKO1, but I can’t use node “pinctrl_weim_gpio_3”, because It’s in &iomuxc.
Which node can I use? Should I and can I create a new node?
Other question how do I set the clock frequency?
Thanks for your help.
Regards Davide
Hi
Note that the macro name is constructed as __.
I would delete the MX6QDL_PAD_GPIO_19__GPIO4_IO05 from the pinctrl_weim_gpio_3 and create an additional pinctrl group with only the GPIO19 ball muxed for CLK01.
Then, as you don’t really want to tie it to a driver I would add that addtional pinctrl group to the pinctrl-0 property of iomuxc.
That should do the trick to output CLKO1.
Note that the SGTL5000 audio codec on the module uses CLKO1, so by changing the frequency funny things will happen.
The 24MHz used for the codec are hardcoded here. Please refer to the i.MX6DL/S reference manual on what configuration option you have on CLKO1.
You might be able to change the clock in the device tree. E.g. have a look here.
Max
Hi Max, thank you for your replay. I will try your advice.
I will inform you of the result.
Regards Davide
Thank you Max, your advice has been corrected. Regards Davide
