which command I can use to set an ip for my module, that I formatted lately. I access the bootloader via rs232 and then the command prompt where I set the ip:
set ip.ip 10.10.0.1
set ip.subnet 255.255.255.0
set ip.dhcp 0
save ip
But no ping, I wanted later to access the http and set my new username and password.
Which steps should I take to load a new OSimage?
Thanks in advance!
The ip address in the bootloader is only used for the bootloader functions (download image).
WinCe uses an independent setting which you can configure in the Control Panel:
Start → Settings → Control Panel → Network and Dial-up Connections
The problem is that I dont have access to windows at all after I formatted the module, I got a black screen, no way I can get to control panel. The console is the only thing I can get access to via rs232.
