I would like to set the hostname via the wrapup.sh script after successful image installation. It’s generated from the MAC address and I have the script to generate the full hostname, but I’m not sure how to write it into /etc/hostname
Hello! You can absolutely set the hostname using the wrapup.sh script after a successful installation with the Toradex Easy Installer.
After your product ID validation in wrapup.sh, simply append your hostname generation logic and then write the hostname directly into /etc/hostname. For example:
# Example: Generate hostname from MAC address (replace with your actual logic)
MAC=$(cat /sys/class/net/eth0/address | sed 's/://g')
HOSTNAME="mydevice-$MAC"
# Write the generated hostname to /etc/hostname
echo "$HOSTNAME" > $ROOTFS_DIR/etc/hostname
# Optionally, set the hostname immediately for the installation environment
echo "$HOSTNAME" > /proc/sys/kernel/hostname
Please note:
$ROOTFS_DIRpoints to the directory representing the target root filesystem (as used inwrapup.shscripts).- If your script is more complex, just ensure the output is a single line (the desired hostname).
- You do not need to reboot for this change to persist—the hostname will be set on the next system boot automatically.
Keep in mind: If you are using a read-only root filesystem, persistent modifications at runtime aren’t possible (details).
You can find additional context here:
@ToradexAI unfortunately the variable $ROOTFS_DIR is empty inside the wrapup.sh script.
Thanks for your response.
Please remember to tick the “Solution” checkbox below if my response solves your question. If you have follow-up questions, just continue to tag me using @ToradexAI in your new posts.
Thank you for the clarification!
You’re correct: within the wrapup.sh script, the $ROOTFS_DIR variable isn’t available. Since wrapup.sh runs after the image installation is completed, you need to modify the target system by mounting its root filesystem directly.
Here’s an example that:
- Mounts the installed rootfs partition (usually /dev/mmcblk0p2 for eMMC)
- Writes the generated hostname to /etc/hostname in the installed system
- Unmounts the partition afterward
#!/bin/sh
# Example: Adapt to your validation logic if necessary
# case $PRODUCT_ID in
# 0027|0028|0029|0035|0082|0083|0084|0085) ;;
# 0014|0015|0016|0017|0077|0078|0079|0080) ;;
# *) error_exit "This script is meant to be run on a supported module. Aborting...";;
# esac
# Generate hostname from MAC address as desired
# Mount the rootfs partition (usually the 2nd partition)
mkdir -p /tmp/target_rootfs
mount /dev/mmcblk0p2 /tmp/target_rootfs
# Set /etc/hostname in the installed system
echo "$HOSTNAME" > /tmp/target_rootfs/etc/hostname
# Unmount and cleanup
umount /tmp/target_rootfs
rmdir /tmp/target_rootfs
# Optionally, reboot
# reboot -f
exit 0
Key points:
- Always check that /dev/mmcblk0p2 is the correct partition for your device and storage.
- Adjust the MAC address interface (eth0) if needed.
- The partition scheme might differ if you use SD cards or NAND.
For more information, see:
@ToradexAI I mounted my root partition /dev/mmcblk0p1 to /var/volatile/_temp.
I found the hostname file - in my case it’s /var/volatile/_temp/ostree/deploy/torizon/deploy/1831fbeea5efb994cd9c532168cb6abb80997e2789b11a710d12f7075b4b00b6.0/etc/hostname
unfortunately there is a random directory name involved. In my case that’s 1831fbeea5efb994cd9c532168cb6abb80997e2789b11a710d12f7075b4b00b6.0. How can I know the name of this random directory?
Great question! That "random" directory name is actually the OSTree commit hash, representing the specific deployment of your Torizon OS image. Each new deployment gets a unique, cryptographically generated hash (OSTree details).
To handle this in your wrapup.sh script, you can dynamically find the correct deployment directory with a wildcard/globbing pattern. Here’s an example:
#!/bin/shMount the rootfs partition
mkdir -p /var/volatile/_temp
mount /dev/mmcblk0p1 /var/volatile/_tempGenerate hostname from MAC address
MAC=$(cat /sys/class/net/eth0/address | sed ‘s/://g’)
HOSTNAME=“mydevice-$MAC”Find the deployment directory dynamically
DEPLOY_DIR=$(ls -d /var/volatile/_temp/ostree/deploy/torizon/deploy/*.0 | head -1)
if [ -n “$DEPLOY_DIR” ]; then
# Write hostname to the deployment’s /etc/hostname
echo “$HOSTNAME” > “$DEPLOY_DIR/etc/hostname”
echo “Hostname set to: $HOSTNAME”
else
echo “Error: Could not find deployment directory”
fiUnmount and cleanup
umount /var/volatile/_temp
rmdir /var/volatile/_temp
exit 0
This method will always target the correct deployed rootfs, regardless of the OSTree commit hash, making your script reliable after every installation/update cycle.
- Learn more about deployment and commit directories: https://developer.toradex.com/torizon/in-depth/ostree/#description
Hi @tw.apex
Can you elaborate on what is your objective here?
Since the MAC address is already derived from the SN ![]()
which in turn is part of the hostname
Hi @allan.tx, we have our own MAC address range which we want to use. Also we want to use a specific prefix to the hostname, followed by a random 4-digit value based on the mac address (like this: gcu-ABCD.local). the default hostname does not suit us. It would be nice to have a hook when assigning the MAC address (TEZI is currently always replacing it with a default one) and generating the hostname - especially because we also use avahi services to announce our device on the network and there I need a proper hostname. best, Tilli
The default hostname set is a one-shot service; you can try a similar approach.
set-hostname.service
[Unit]
ConditionFileNotEmpty=|!/etc/hostname
Wants=network-pre.target
Before=network-pre.target
After=local-fs.target
After=sys-subsystem-net-devices-eth0.device
[Service]
Type=oneshot
ExecStart=/usr/bin/sethostname
[Install]
WantedBy=network.target
sethostname
/usr/bin/hostnamectl set-hostname ${hostname}
I actually did exactly that - I just thought it was overkill and wanted to do it in the wrapup script instead
but now I’m actually running my service before your set-hostname.service ![]()
