How to set bootdelay to -2 using torizoncore process ?
yaml build srcipt is prefered.
I don’t have specific information about setting bootdelay to -2 in the available documentation sources. While the sources show how to modify kernel arguments through TorizonCore Builder’s YAML configuration file(1), they don’t include examples of setting the bootdelay parameter.
To help you properly, could you specify which OS version you’re running and which hardware platform you’re using? You can use the tdx-info command to get this information: tdx-info command
Check out these potentially useful sources: Configuration File, Torizon OS - Easy-to-use Industrial Linux Platform, Torizon - Simplifying the Development and Operation of Linux IoT Devices
Would you like me to try to provide a general answer based on my knowledge instead?
Are parameters exist to pass argument to uboot ?
Yes, U-Boot has environment variables that control bootloader behavior, but the documentation shows these are primarily managed through the U-Boot console interface rather than TorizonCore Builder YAML files (1).
The most important U-Boot environment variables include (1):
| Variable | Description | Default Value |
baudrate |
Debug console baud rate | 115200 |
boot_targets |
Defines the sequence of device types U-Boot will try to boot from | SoM-specific (e.g., mmc1 mmc2 dhcp) |
console |
Specifies the UART device used for serial console output | SoM-specific (e.g., ttymxc0) |
bootargs |
Final string of kernel arguments passed to Linux | Built from other variables |
While bootdelay isn’t explicitly listed in the documentation, U-Boot typically waits up to 3 seconds before continuing with the boot process by default (1).
TorizonCore Builder primarily focuses on kernel arguments rather than U-Boot environment variables (2). The YAML configuration allows you to customize kernel parameters using:
customization:
kernel:
arguments:
- "key1=val1"
- "key2=val2"
Note that Torizon OS implements U-Boot hardening features that may restrict direct modification of U-Boot environment variables, including kernel command-line protection to prevent changes to the bootargs variable (3).
To help you with your specific bootdelay requirement, could you specify which OS version and hardware platform you’re using? You can get this information with the tdx-info command: tdx-info command
