I want 115200 Baudrate, No-Parity, No-Flow Control, One stop bit UART comminication.
My termios configuration like below, but device receive 7 bit data (maximum value 127).
The target device receives a maximum value of 127 but the transmitters are sending 8 bits of data.
fd = open(device, O_RDWR | O_NOCTTY | O_NDELAY);
if(fd == -1) perror("SERIAL: Unable to open port ");
else fcntl(fd, F_SETFL, FNDELAY);
struct termios port_settings;
cfsetispeed(&port_settings, B115200);
cfsetospeed(&port_settings, B115200);
port_settings.c_cflag &= ~PARENB;
port_settings.c_cflag &= ~CSTOPB;
port_settings.c_cflag &= ~CSIZE;
port_settings.c_cflag |= CS8;
tcsetattr(fd, TCSANOW, &port_settings);
NOTE: Transmitter works fine.
Why this occurs?
I’m using Colibri iMX6ULL 512MB WB IT V1.1A with Iris Rev. 2.0.
Best regards.
Hi @hyaldiz ,
Have you checked if the data you’re transmitting is in the two’s complement representation (from -128 to 127)?
Also, I was searching for the termios flags, and I found a good guide that might help you:
https://www.ibm.com/docs/en/aix/7.1?topic=files-termiosh-file
Hiago.
DaveM
June 29, 2022, 10:07pm
#3
You should also tcgetattr(fd, &port_settings) before modification. I also find it comforting to set all kinds of bits in that port_settings structure and not rely on anything to be set up properly in there for me.
Everything works fine like below, thanks for the help.
tcgetattr(fd, &port_settings); //Get the current attributes of the serial port
port_settings.c_cflag &= ~CRTSCTS; //Disable Hardware Flow Control
port_settings.c_iflag &= ~(IGNBRK | BRKINT | PARMRK | ISTRIP
| INLCR | IGNCR | ICRNL | IXON);
port_settings.c_oflag &= ~OPOST;
port_settings.c_lflag &= ~(ECHO | ECHONL | ICANON | ISIG | IEXTEN);
Dear @hyaldiz ,
Thanks for the update. So it seems that you solved your issue, right? Can we mark this as solved?
Dear @gclaudino.tx ,
Yes, issue solved. You can mark as solved.
Best regards.
