Sensoray 1012 on IMX8
I am planning to work Apalis IMX8 and Ixora Carrier with Sensoray
Model-1012(8-channel frame grabber and 8-channel audio capture | Model 1012)
There is a guideline that sensoray provides for IMX6 :
but i dont know how to work with it on IMX8.
When i contact with Sensoray tech support they said it is possible with manual config.
As far as i got stuck with finding the right image that guide line point at this line:
wget http://developer1.toradex.com/files/toradex-dev/uploads/media/Colibri/Linux/Images/old/Apalis_iMX6_LinuxImageV2.4Beta1_20150518.tar.bz2
after this line idk if there is any other possible problem that i am going to face.
Greetings @Engineering_AV,
I don’t personally have any experience with this particular hardware peripheral, but I gave the instructions from Sensoray a quick look-through. It seems fairly simple just need to enable a kernel configuration for the driver of this device, then recompile the kernel. However the instructions from Sensoray seem a bit outdated.
Please consult our article here: Build From Source Code Documentation Overview | Toradex Developer Center
It has everything from getting the right toolchain, kernel sources, and other components. Then as Sensoray stated just add the config for this device manually and re-compile the kernel.
Thank you for your reply.
The point i got stuck with sensoray guide and toradex build u-boot and linux kernal guide is kinda same.
In this guide:
There is “Linux Image / Flashing Tools” section and there i cant find the right BSP demo image for Apalis Imx8 in this link High performance, low power | Footprint for embedded computing
Oh that link is for our older version images. If you’re working on our newer images like Torizon you can download the latest stable images from here: Toradex Easy Installer Documentation Overview | Toradex Developer Center
