I am working on Col iMX6ULL 512 MB IT V1.0 A SOM and Colibri Evaluation Board 3.2 B. Every time i modified the dtb file i need to flash the toradex easy installer via USB RNDIS Ethernet Interface in recovery mode and then with pen drive i need to load the whole image with modified dtb. This is taking time. So please suggest me how to load modified dtb file directly to uboot via Ethernet or UART and then running the image.
On Colibri iMX6ULL device tree is kept on separate UBI partition as a binary. You can ether update a device tree using commands ubiupdatevol at Linux or ubi write at U_Boot
At U_Boot level you will need to use an SD card or USB flash to copy DTB from. At Linux you can also use scp command to copy DTB file over network.
