Sending file over serial port
Currently, im sending file to toradex module over ethernet from linux os with scp command.But now, im tryring to same files to toradex module from linux os. I couldnt find a good guide.
Can you help for this issue ?
Thank you
You can use ZMODEM, YMODEM or XMODEM protocols. Most terminal program like minicom, PuTty, TeraTerm are natively supports them. Or you can use a cli commands.
I’d recommend to use a ZMODEM.
