I am trying to build a custom kernel to change a few configurations from the default image and adding some changes to the code. I am following this documentation to configure and compile the kernel and I upload it to the target using the Legacy images method where I use an SD to upload the changes. The things I compile are the kernel and a .dtb for Ixora v1.1:
make -j3 uImage LOADADDR=10008000 2>&1 | tee build.log
make imx6q-apalis-ixora-v1.1.dtb
When I get to the point of running the ‘run update_fdt’ on the target the system looks for another .dtb which I didn’t compile. I get the following response:
Apalis iMX6 # run update_fdt
reading apalis_imx6/imx6q-apalis-eval.dtb
I would expect the system to read the ’ imx6q-apalis-ixora-v1.1.dtb’ instead. Is it correct? how can I assure that the system is using my compiled .dtb file? I suspect it is avoiding my changes.
Best regards, Alex
