I am trying to bring up Xorg without lxdm desktop. X can be launched after lxdm.service is terminated. But it is failed to launch ‘xrandr’ or ‘xinput_calibrator’, there is segmentation error from Xorg.
root@apalis-imx6:~# systemctl stop lxdm.service
root@apalis-imx6:~# X &
[1] 685
root@apalis-imx6:~#
X.Org X Server 1.17.2
Release Date: 2015-06-16
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.13.0-101-generic x86_64
Current Operating System: Linux apalis-imx6 3.14.52-v2.6.1b1+g3894f6d #1 SMP Mon Nov 14 14:51:26 CST 2016 armv7l
Kernel command line: enable_wait_mode=off vmalloc=400M ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 rootwait fec_mac=00:
14:2d:4a:30:08 consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 mxc_hdmi.only_cea=1 video=mxcfb0:dev=hdm
i,1920x1080M@60,if=RGB24 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M
Build Date: 14 November 2016 03:26:52PM
Current version of pixman: 0.32.6
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov 24 09:28:03 2016
([ 49.060756] mxc_sdc_fb fb.20: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 49.125086] mxc_sdc_fb fb.20: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 49.194083] mxc_sdc_fb fb.20: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 49.264339] mxc_sdc_fb fb.20: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 49.642247] mxc_sdc_fb fb.20: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
root@apalis-imx6:~# xrandr
Screen 0: minimum 240 x 240, current 1920 x 1080, maximum 8192 x 8192
DISP3 BG connected 1920x1080+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
D:1920x1080p-60 60.00*+
V:640x480p-60 60.00
root@apalis-imx6:~# [ 59.620865] mxc_sdc_fb fb.20: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 59.684183] mxc_sdc_fb fb.20: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 59.754309] mxc_sdc_fb fb.20: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
(EE)
(EE) Backtrace:
(EE)
(EE) Segmentation fault at address 0x65627553
(EE)
Fatal server error:
(EE) Caught signal 11 (Segmentation fault). Server aborting
(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
Is the way wrong to start Xorg ? Thanks!
