I have a Verdin IMX8MP on a custom carrier board that has a KSZ9031 as the PHY for the secondary ethernet port (end1). The port always fails to communicate with my DHCP server and get an IPv4 address assigned. The primary ethernet port (end0) works fine, and I’ve tried swapping the cables with no luck.
I’ve also tried statically assigning an IP address to the end1. When doing so, the IP address shows up on a network scan, but it shows the MAC address of end0.
I’m using Yocto BSP 7.5.0, heres a snippet of my device tree:
#include "imx8mp-verdin.dtsi"
#include "imx8mp-verdin-wifi.dtsi"
/* Verdin ETH_2 RGMII */
/delete-node/ &verdin_eth2_mdio;
&fec {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&pinctrl_fec>;
pinctrl-1 = <&pinctrl_fec_sleep>;
phy-mode = "rgmii-id";
phy-handle = <ðphy1>;
fsl,magic-packet;
verdin_eth2_mdio: mdio {
#address-cells = <1>;
#size-cells = <0>;
ethphy1: ethernet-phy@2 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <0x2>;
interrupt-parent = <&gpio4>;
interrupts = <18 IRQ_TYPE_LEVEL_LOW>;
enet-phy-lane-swap;
running 'ip addr':
2: end1: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:14:2d:94:8c:1a brd ff:ff:ff:ff:ff:ff
inet 169.254.46.186/16 brd 169.254.255.255 scope global end1
valid_lft forever preferred_lft forever
inet6 fe80::214:2dff:fe94:8c1a/64 scope link proto kernel_ll
3: end0: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:14:2d:84:8c:1a brd ff:ff:ff:ff:ff:ff
inet 192.168.1.214/24 brd 192.168.1.255 scope global end0
inet6 fe80::214:2dff:fe84:8c1a/64 scope link proto kernel_ll
running 'ethtool end1':
Settings for end1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
master-slave cfg: preferred slave
master-slave status: slave
Port: Twisted Pair
PHYAD: 2
Transceiver: external
MDI-X: Unknown
Supports Wake-on: g
Wake-on: d
Link detected: yes
Any help here would be greatly appreciated.
Further Testing:
I followed this documentation to manually configure the ports.
systemctl stop connman.service
systemctl stop systemd-networkd.socket
systemctl stop systemd-networkd.service
- Confirmed neither port is no longer detected on the network
Try manual configuration with known working port (end0):
ip link set end0 up
ip addr add 192.168.1.26/24 broadcast 192.168.1.255 dev end0
ip route add default via 192.168.1.1
- Confirmed end0 detected on network scan.
Attempted to enable end1:
ip link set end1 up
ip addr add 192.168.1.27/24 broadcast 192.168.1.255 dev end7
(ERROR): RTNETLINK answers: File exists
Retry after flushing alll:
ip addr flush dev end0
ip route flush dev end0
ip link set end0 down
ip addr flush dev end1
ip route flush dev end1
ip link set end1 down
ip link set end1 up
ip addr add 192.168.1.27/24 broadcast 192.168.1.255 dev end1
- end1 not detected by network scan
