I have to bring up SDIO 3.0 card on Apalis EVB V1.1A SD1 4-bit mode SDIO port X19.
From Apalis iMX6 SoM datasheet, I can confirm that there is support for SDR104 mode.
Remove R29,R30,R31,R32,R39 pull ups near X19 connector to enable hardware support.
Also in imx6qdl-apalis.dtsi generated from oe-core Yocto Rocko build,
/* SD1 */
&usdhc2 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usdhc2 &pinctrl_sd_cd>;
cd-gpios = <&gpio6 14 GPIO_ACTIVE_LOW>;
vqmmc-supply = <& reg_3p3v>;
bus-width = < 4 >;
voltage-ranges = < 3300 3300 >;
status = "disabled";
pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17071
MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10071
MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17071
MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17071
MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17071
MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17071
So I think SDR104 should work straight away if I follow above changes right. Is my thinking correct?
Also can anyone please suggest us how to get to know information regarding pin name and values
Eg: MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17071
Thanks,
Sridhar
