Sure. A couple notes about this custom Linux distro that may be relevant
root@acu3:~# dmesg
[ 0.000000] Linux version 6.0.5-rt14-6.1.0-devel+git.040e3123e9d9 (oe-user@oe-host) (arm-tdx-linux-gnueabi-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT_RT Thu Oct 27 07:48:28 UTC 2022
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Toradex Apalis iMX6Q/D Module on ACU-3 Carrier Board
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 256 MiB at 0x80000000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000010000000-0x0000000035ffffff]
[ 0.000000] HighMem [mem 0x0000000036000000-0x000000008fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000010000000-0x000000008fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000010000000-0x000000008fffffff]
[ 0.000000] percpu: Embedded 17 pages/cpu s39892 r8192 d21548 u69632
[ 0.000000] pcpu-alloc: s39892 r8192 d21548 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 523072
[ 0.000000] Kernel command line: enable_wait_mode=off vmalloc=400M root=PARTUUID=5f29b799-02 ro rootwait fec_mac=00:14:2d:a4:5d:78 consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 mxc_hdmi.only_cea=1 fbmem=32M
[ 0.000000] Unknown kernel command line parameters “enable_wait_mode=off fec_mac=00:14:2d:a4:5d:78 fbmem=32M”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1790316K/2097152K available (12288K kernel code, 1839K rwdata, 4140K rodata, 1024K init, 6687K bss, 44692K reserved, 262144K cma-reserved, 1212416K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] Running RCU self tests
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU lockdep checking is enabled.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C-310 errata 752271 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 16 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76470001
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000001] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000029] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.003068] Console: colour dummy device 80x30
[ 0.008692] printk: console [tty1] enabled
[ 0.008703] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[ 0.008708] … MAX_LOCKDEP_SUBCLASSES: 8
[ 0.008713] … MAX_LOCK_DEPTH: 48
[ 0.008717] … MAX_LOCKDEP_KEYS: 8192
[ 0.008723] … CLASSHASH_SIZE: 4096
[ 0.008729] … MAX_LOCKDEP_ENTRIES: 32768
[ 0.008734] … MAX_LOCKDEP_CHAINS: 65536
[ 0.008740] … CHAINHASH_SIZE: 32768
[ 0.008745] memory used by lock dependency info: 4061 kB
[ 0.008751] memory used for stack traces: 2112 kB
[ 0.008757] per task-struct memory footprint: 1536 bytes
[ 0.008930] Calibrating delay loop (skipped), value calculated using timer frequency… 6.00 BogoMIPS (lpj=30000)
[ 0.008948] pid_max: default: 32768 minimum: 301
[ 0.011250] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.011290] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.020596] CPU: Testing write buffer coherency: ok
[ 0.020945] CPU0: Spectre v2: using BPIALL workaround
[ 0.023989] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.035399] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.035497] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.036938] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.038195] Running RCU-tasks wait API self tests
[ 0.140474] Setting up static identity map for 0x10100000 - 0x10100078
[ 0.144600] rcu: Hierarchical SRCU implementation.
[ 0.144607] rcu: Max phase no-delay instances is 1000.
[ 0.145431] printk: console [tty1] printing thread started
[ 0.157082] smp: Bringing up secondary CPUs …
[ 0.168665] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.168686] CPU1: Spectre v2: using BPIALL workaround
[ 0.181310] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.181330] CPU2: Spectre v2: using BPIALL workaround
[ 0.182456] Callback from call_rcu_tasks_trace() invoked.
[ 0.192066] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.192083] CPU3: Spectre v2: using BPIALL workaround
[ 0.193035] smp: Brought up 1 node, 4 CPUs
[ 0.193050] SMP: Total of 4 processors activated (24.00 BogoMIPS).
[ 0.193801] CPU: All CPU(s) started in SVC mode.
[ 0.201768] devtmpfs: initialized
[ 0.561336] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.567202] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.567287] futex hash table entries: 1024 (order: 5, 131072 bytes, linear)
[ 0.580069] Callback from call_rcu_tasks() invoked.
[ 0.586188] pinctrl core: initialized pinctrl subsystem
[ 0.608071] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.721012] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.751874] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.752967] cpuidle: using governor menu
[ 0.753100] CPU identified as i.MX6Q, silicon rev 1.6
[ 1.015127] platform 2800000.ipu: Fixing up cyclic dependency with 20e0000.iomuxc-gpr:ipu2_csi1_mux
[ 1.071917] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 1.071936] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 1.091347] imx6q-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[ 1.338524] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 1.655988] SCSI subsystem initialized
[ 1.656862] libata version 3.00 loaded.
[ 1.662370] usbcore: registered new interface driver usbfs
[ 1.663496] usbcore: registered new interface driver hub
[ 1.664198] usbcore: registered new device driver usb
[ 1.665934] usb_phy_generic usbphynop1: supply vcc not found, using dummy regulator
[ 1.669706] usb_phy_generic usbphynop1: dummy supplies not allowed for exclusive requests
[ 1.671543] usb_phy_generic usbphynop2: supply vcc not found, using dummy regulator
[ 1.674620] usb_phy_generic usbphynop2: dummy supplies not allowed for exclusive requests
[ 1.731234] stmpe-i2c 2-0041: stmpe811 detected, chip id: 0x811
[ 1.888378] i2c i2c-2: IMX I2C adapter registered
[ 1.896942] mc: Linux media interface: v0.10
[ 1.898154] videodev: Linux video capture interface: v2.00
[ 1.900928] pps_core: LinuxPPS API ver. 1 registered
[ 1.900939] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.901184] PTP clock support registered
[ 1.921259] Bluetooth: Core ver 2.22
[ 1.921737] NET: Registered PF_BLUETOOTH protocol family
[ 1.921746] Bluetooth: HCI device and connection manager initialized
[ 1.922059] Bluetooth: HCI socket layer initialized
[ 1.922159] Bluetooth: L2CAP socket layer initialized
[ 1.922674] Bluetooth: SCO socket layer initialized
[ 1.932667] clocksource: Switched to clocksource mxc_timer1
[ 1.942116] VFS: Disk quotas dquot_6.6.0
[ 1.943099] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.096655] NET: Registered PF_INET protocol family
[ 2.099617] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 2.107512] tcp_listen_portaddr_hash hash table entries: 512 (order: 3, 36864 bytes, linear)
[ 2.108366] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 2.108516] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 2.109990] TCP bind hash table entries: 8192 (order: 7, 589824 bytes, linear)
[ 2.112763] TCP: Hash tables configured (established 8192 bind 8192)
[ 2.114411] UDP hash table entries: 512 (order: 4, 81920 bytes, linear)
[ 2.115086] UDP-Lite hash table entries: 512 (order: 4, 81920 bytes, linear)
[ 2.117220] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 2.124965] RPC: Registered named UNIX socket transport module.
[ 2.124999] RPC: Registered udp transport module.
[ 2.125020] RPC: Registered tcp transport module.
[ 2.125040] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.125105] PCI: CLS 0 bytes, default 64
[ 2.137288] armv7-pmu pmu: hw perfevents: no interrupt-affinity property, guessing.
[ 2.139125] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 2.171232] Initialise system trusted keyrings
[ 2.173946] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[ 2.359214] NFS: Registering the id_resolver key type
[ 2.359646] Key type id_resolver registered
[ 2.359679] Key type id_legacy registered
[ 2.361726] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.361967] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.458781] Key type asymmetric registered
[ 2.459064] Asymmetric key parser ‘x509’ registered
[ 2.463055] bounce: pool size: 64 pages
[ 2.465664] io scheduler mq-deadline registered
[ 2.465692] io scheduler kyber registered
[ 2.538214] mxs-dma 110000.dma-apbh: initialized
[ 2.581610] pfuze100-regulator 2-0008: Full layer: 2, Metal layer: 1
[ 2.583618] pfuze100-regulator 2-0008: FAB: 0, FIN: 0
[ 2.583635] pfuze100-regulator 2-0008: pfuze100 found.
[ 2.694616] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 268, base_baud = 5000000) is a IMX
[ 2.696665] printk: console [ttymxc0] printing thread started
[ 2.698430] printk: console [ttymxc0] enabled
[ 2.729236] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 269, base_baud = 5000000) is a IMX
[ 2.742714] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 270, base_baud = 5000000) is a IMX
[ 2.756768] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 271, base_baud = 5000000) is a IMX
[ 2.769927] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 272, base_baud = 5000000) is a IMX
[ 2.870994] etnaviv etnaviv: bound 130000.gpu (ops gpu_ops)
[ 2.875058] etnaviv etnaviv: bound 134000.gpu (ops gpu_ops)
[ 2.878626] etnaviv etnaviv: bound 2204000.gpu (ops gpu_ops)
[ 2.878675] etnaviv-gpu 130000.gpu: model: GC2000, revision: 5108
[ 2.884956] etnaviv-gpu 134000.gpu: model: GC320, revision: 5007
[ 2.885377] etnaviv-gpu 2204000.gpu: model: GC355, revision: 1215
[ 2.885396] etnaviv-gpu 2204000.gpu: Ignoring GPU with VG and FE2.0
[ 2.897469] [drm] Initialized etnaviv 1.3.0 20151214 for etnaviv on minor 0
[ 2.921626] imx-ipuv3 2400000.ipu: IPUv3H probed
[ 2.939178] Stack Depot allocating hash table of 65536 entries with kvcalloc
[ 2.955503] imx-drm display-subsystem: bound imx-ipuv3-crtc.2 (ops ipu_crtc_ops)
[ 2.959239] imx-drm display-subsystem: bound imx-ipuv3-crtc.3 (ops ipu_crtc_ops)
[ 2.964307] imx-drm display-subsystem: bound imx-ipuv3-crtc.6 (ops ipu_crtc_ops)
[ 2.968233] imx-drm display-subsystem: bound imx-ipuv3-crtc.7 (ops ipu_crtc_ops)
[ 2.976132] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 1
[ 2.977176] imx-ipuv3 2800000.ipu: IPUv3H probed
[ 3.168126] brd: module loaded
[ 3.327969] loop: module loaded
[ 3.335821] ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
[ 3.335845] ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
[ 3.335860] ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
[ 3.335876] ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
[ 3.336859] ahci-imx 2200000.sata: supply ahci not found, using dummy regulator
[ 3.340212] ahci-imx 2200000.sata: supply phy not found, using dummy regulator
[ 3.341891] ahci-imx 2200000.sata: supply target not found, using dummy regulator
[ 3.348859] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
[ 3.348892] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 3.348912] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 3.372827] scsi host0: ahci-imx
[ 3.381633] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 284
[ 3.421263] CAN device driver interface
[ 3.487781] pps pps0: new PPS source ptp0
[ 3.546016] fec 2188000.ethernet eth0: registered PHC device 0
[ 3.555598] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.555612] ehci-pci: EHCI PCI platform driver
[ 3.557365] usbcore: registered new interface driver usb-storage
[ 3.608932] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[ 3.610651] i2c_dev: i2c /dev entries driver
[ 3.621582] pps_ldisc: PPS line discipline registered
[ 3.627672] pps pps1: new PPS source pps.-1
[ 3.629649] pps pps1: Registered IRQ 66 as PPS source
[ 3.659793] Bluetooth: HCI UART driver ver 2.3
[ 3.659813] Bluetooth: HCI UART protocol H4 registered
[ 3.660293] Bluetooth: HCI UART protocol LL registered
[ 3.676371] sdhci: Secure Digital Host Controller Interface driver
[ 3.676382] sdhci: Copyright(c) Pierre Ossman
[ 3.676388] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.690700] sdhci-esdhc-imx 2190000.mmc: Got CD GPIO
[ 3.692449] caam 2100000.crypto: Entropy delay = 3200
[ 3.723848] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.724587] ahci-imx 2200000.sata: no device found, disabling link.
[ 3.724599] ahci-imx 2200000.sata: pass ahci_imx…hotplug=1 to enable hotplug
[ 3.753681] caam 2100000.crypto: Instantiated RNG4 SH0
[ 3.770038] mmc0: SDHCI controller on 2190000.mmc [2190000.mmc] using ADMA
[ 3.775103] mmc2: SDHCI controller on 2198000.mmc [2198000.mmc] using ADMA
[ 3.814444] caam 2100000.crypto: Instantiated RNG4 SH1
[ 3.814534] caam 2100000.crypto: device ID = 0x0a16010000000000 (Era 4)
[ 3.814548] caam 2100000.crypto: job rings = 2, qi = 0
[ 3.824327] mmc0: new high speed SD card at address 0007
[ 3.840598] mmcblk0: mmc0:0007 DDINC 1.85 GiB
[ 3.844037] mmc2: new DDR MMC card at address 0001
[ 3.854233] mmcblk2: mmc2:0001 Q2J54A 3.59 GiB
[ 3.858380] caam algorithms registered in /proc/crypto
[ 3.859503] caam 2100000.crypto: registering rng-caam
[ 3.879060] caam 2100000.crypto: rng crypto API alg registered prng-caam
[ 3.908802] usbcore: registered new interface driver usbhid
[ 3.908815] usbhid: USB HID core driver
[ 3.925200] imx-ipuv3-csi imx-ipuv3-csi.0: Registered ipu1_csi0 capture as /dev/video0
[ 3.930419] imx-ipuv3 2400000.ipu: Registered ipu1_ic_prpenc capture as /dev/video1
[ 3.936046] imx-ipuv3 2400000.ipu: Registered ipu1_ic_prpvf capture as /dev/video2
[ 3.945401] imx-ipuv3-csi imx-ipuv3-csi.1: Registered ipu1_csi1 capture as /dev/video3
[ 3.946112] mmcblk0: p1
[ 3.952289] mmcblk2: p1 p2
[ 3.952703] imx-ipuv3-csi imx-ipuv3-csi.4: Registered ipu2_csi0 capture as /dev/video4
[ 3.964240] imx-ipuv3 2800000.ipu: Registered ipu2_ic_prpenc capture as /dev/video5
[ 3.968422] imx-ipuv3 2800000.ipu: Registered ipu2_ic_prpvf capture as /dev/video6
[ 3.974827] imx-ipuv3-csi imx-ipuv3-csi.5: Registered ipu2_csi1 capture as /dev/video7
[ 3.977442] mmcblk2boot0: mmc2:0001 Q2J54A 16.0 MiB
[ 3.992500] stmpe-adc stmpe-adc: DMA mask not set
[ 4.016562] mmcblk2boot1: mmc2:0001 Q2J54A 16.0 MiB
[ 4.055627] mmcblk2rpmb: mmc2:0001 Q2J54A 512 KiB, chardev (243:0)
[ 4.058224] random: crng init done
[ 4.063763] NET: Registered PF_INET6 protocol family
[ 4.082997] Segment Routing with IPv6
[ 4.083271] In-situ OAM (IOAM) with IPv6
[ 4.083829] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 4.095843] NET: Registered PF_PACKET protocol family
[ 4.095998] can: controller area network core
[ 4.096873] NET: Registered PF_CAN protocol family
[ 4.096910] can: raw protocol
[ 4.097290] can: broadcast manager protocol
[ 4.097442] can: netlink gateway - max_hops=1
[ 4.100364] Key type dns_resolver registered
[ 4.155648] Registering SWP/SWPB emulation handler
[ 4.160241] Loading compiled-in X.509 certificates
[ 4.968782] video-mux 20e0000.iomuxc-gpr:ipu2_csi1_mux: Consider updating driver video-mux to match on endpoints
[ 5.018700] imx-media: Registered ipu_ic_pp csc/scaler as /dev/video8
[ 5.041489] imx_thermal 20c8000.anatop:tempmon: Industrial CPU temperature grade - max:105C critical:105C passive:95C
[ 5.066344] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.098961] input: gpio-pbs as /devices/platform/gpio-pbs/input/input1
[ 5.184481] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 5.185414] VFS: Mounted root (ext4 filesystem) readonly on device 179:10.
[ 5.191018] devtmpfs: mounted
[ 5.198106] Freeing unused kernel image (initmem) memory: 1024K
[ 5.204829] Run /sbin/init as init process
[ 5.204840] with arguments:
[ 5.204845] /sbin/init
[ 5.204850] with environment:
[ 5.204854] HOME=/
[ 5.204859] TERM=linux
[ 5.204863] enable_wait_mode=off
[ 5.204867] fec_mac=00:14:2d:a4:5d:78
[ 5.204872] fbmem=32M
[ 5.657590] systemd[1]: System time before build time, advancing clock.
[ 5.892155] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 5.898931] systemd[1]: Detected architecture arm.
[ 5.974726] systemd[1]: Hostname set to .
[ 5.991715] systemd[1]: Initializing machine ID from random generator.
[ 5.997555] systemd[1]: Installed transient /etc/machine-id file.
[ 8.209986] systemd[1]: Queued start job for default target Multi-User System.
[ 8.599797] systemd[1]: Created slice Slice /system/getty.
[ 8.663264] systemd[1]: Created slice Slice /system/modprobe.
[ 8.719691] systemd[1]: Created slice Slice /system/serial-getty.
[ 8.788854] systemd[1]: Created slice User and Session Slice.
[ 8.845748] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 8.901992] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.945492] systemd[1]: Reached target Path Units.
[ 8.984714] systemd[1]: Reached target Remote File Systems.
[ 9.034497] systemd[1]: Reached target Slice Units.
[ 9.064774] systemd[1]: Reached target Swaps.
[ 9.395892] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 9.445067] systemd[1]: Reached target RPC Port Mapper.
[ 9.471891] systemd[1]: Listening on Syslog Socket.
[ 9.521938] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.623376] systemd[1]: Journal Audit Socket was skipped because of a failed condition check (ConditionSecurity=audit).
[ 9.629522] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.710561] systemd[1]: Listening on Journal Socket.
[ 9.754163] systemd[1]: Listening on Network Service Netlink Socket.
[ 9.809572] systemd[1]: Listening on udev Control Socket.
[ 9.875162] systemd[1]: Listening on udev Kernel Socket.
[ 9.898172] systemd[1]: Listening on User Database Manager Socket.
[ 9.952544] systemd[1]: Huge Pages File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 9.955928] systemd[1]: POSIX Message Queue File System was skipped because of a failed condition check (ConditionPathExists=/proc/sys/fs/mqueue).
[ 10.080058] systemd[1]: Mounting Kernel Debug File System…
[ 10.163195] systemd[1]: Mounting Kernel Trace File System…
[ 10.351913] systemd[1]: Mounting Temporary Directory /tmp…
[ 10.443831] systemd[1]: Starting Create List of Static Device Nodes…
[ 10.537757] systemd[1]: Starting Load Kernel Module configfs…
[ 10.614858] systemd[1]: Starting Load Kernel Module drm…
[ 10.686230] systemd[1]: Starting Load Kernel Module fuse…
[ 10.771815] systemd[1]: Starting RPC Bind…
[ 10.779659] fuse: init (API version 7.36)
[ 10.876323] systemd[1]: Starting File System Check on Root Device…
[ 11.048256] systemd[1]: Starting Journal Service…
[ 11.064642] systemd[1]: Load Kernel Modules was skipped because all trigger condition checks failed.
[ 11.105248] systemd[1]: Starting Generate network units from Kernel command line…
[ 11.149699] systemd[1]: Starting Apply Kernel Variables…
[ 11.195928] systemd[1]: Starting Coldplug All udev Devices…
[ 11.495753] systemd[1]: Started RPC Bind.
[ 11.502245] systemd[1]: Mounted Kernel Debug File System.
[ 11.514874] systemd[1]: Mounted Kernel Trace File System.
[ 11.577006] systemd[1]: Mounted Temporary Directory /tmp.
[ 11.624900] systemd[1]: Finished Create List of Static Device Nodes.
[ 11.683975] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 11.697554] systemd[1]: Finished Load Kernel Module configfs.
[ 11.762406] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 11.773132] systemd[1]: Finished Load Kernel Module drm.
[ 11.809082] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 11.821036] systemd[1]: Finished Load Kernel Module fuse.
[ 11.876957] systemd[1]: Finished File System Check on Root Device.
[ 11.930517] systemd[1]: Finished Generate network units from Kernel command line.
[ 11.988429] systemd[1]: Finished Apply Kernel Variables.
[ 12.160824] systemd[1]: Mounting FUSE Control File System…
[ 12.246876] systemd[1]: Mounting Kernel Configuration File System…
[ 12.304448] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 12.358025] systemd[1]: Started Journal Service.
[ 12.681596] EXT4-fs (mmcblk2p2): re-mounted. Quota mode: none.
[ 13.044159] systemd-journald[251]: Received client request to flush runtime journal.
[ 20.434866] coda 2040000.vpu: Firmware code revision: 46076
[ 20.434965] coda 2040000.vpu: Initialized CODA960.
[ 20.434975] coda 2040000.vpu: Firmware version: 3.1.1
[ 20.550337] coda 2040000.vpu: coda-jpeg-encoder registered as video9
[ 20.560174] coda 2040000.vpu: coda-jpeg-decoder registered as video10
[ 20.567439] coda 2040000.vpu: coda-video-encoder registered as video11
[ 20.588598] coda 2040000.vpu: coda-video-decoder registered as video12
[ 21.186163] imx-sdma 20ec000.sdma: loaded firmware 3.5
[ 35.179989] 8021q: 802.1Q VLAN Support v1.8
[ 35.766917] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 35.881891] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 35.887945] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 35.888116] cfg80211: failed to load regulatory.db
[ 37.392783] Micrel KSZ9031 Gigabit PHY 2188000.ethernet-1:07: attached PHY driver (mii_bus:phy_addr=2188000.ethernet-1:07, irq=58)
[ 40.521535] flexcan 2090000.can can0: bit-timing not yet defined
[ 40.541543] flexcan 2094000.can can1: bit-timing not yet defined
[ 40.695818] fec 2188000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 40.696877] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 42.876523] pps pps2: new PPS source IMX-uart4
[ 42.877136] pps pps2: source “/dev/ttymxc4” added
[ 81.519085] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 86.513409] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 88.513950] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 88.515439] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 143.519756] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 143.521102] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 143.522462] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 144.516258] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 144.549730] pps pps2: removed
[ 145.516073] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 145.517674] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 145.519222] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 145.520929] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 145.522626] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 145.523878] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 148.515076] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 148.517084] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 148.518546] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 195.526633] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 195.528171] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 195.529693] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 195.530835] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 195.611578] systemd-journald[251]: Data hash table of /run/log/journal/41c4f92e33874454972f27847b2ebcd8/system.journal has a fill level at 75.0 (2731 of 3640 items, 2097152 file size, 767 bytes per hash table item), suggesting rotation.
[ 195.611667] systemd-journald[251]: /run/log/journal/41c4f92e33874454972f27847b2ebcd8/system.journal: Journal header limits reached or header out-of-date, rotating.
[ 196.522474] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 196.523854] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 196.525255] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 196.526870] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 196.528010] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 197.522813] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 197.524196] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 2992.306090] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 2992.307259] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 2992.308720] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 2992.310001] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 2992.383858] systemd-journald[251]: Data hash table of /run/log/journal/41c4f92e33874454972f27847b2ebcd8/system.journal has a fill level at 75.0 (2731 of 3640 items, 2097152 file size, 767 bytes per hash table item), suggesting rotation.
[ 2992.383945] systemd-journald[251]: /run/log/journal/41c4f92e33874454972f27847b2ebcd8/system.journal: Journal header limits reached or header out-of-date, rotating.
[ 2994.314127] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 2994.316109] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 2994.317274] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 2995.305162] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 2995.306493] imx-sdma 20ec000.sdma: restart cyclic channel 1
[ 2995.307780] imx-sdma 20ec000.sdma: restart cyclic channel 1
