The Iris 2.0 has an added load switch IC13 to control (enable/disable/power-cycle) Micro SD Card power using software. SODIMM_100 can be used control the load switch. Please check for details:
Thanks!
If I understand correctly, this requires to rebuild the image. Is it possible to only upgrade a piece of software, without rebuilding the full image?
