So, I installed Angstron via easy installer and sdcard auto mount (hotplug) is working. Then I run
opkg update && opkg upgrade
and the automount stopped working. The directory
/media/mmcblk0p1/
is created, but /dev/mmcblk0p1/ is not mounted to it. The sdcard is fat32-formated and working, tested on another computer.
Script /etc/udev/scripts/mount.sh seems to be running and executing ‘mount’, after connecting sdcard the following line appear in ‘journalctl -f’:
colibri-imx6ull root[523]: mount.sh/automount Auto-mount of [/media/mmcblk0p1] successful
Do NOT use opkg upgrade. This may (or less likely may not) update something which we changed to make things work smoother. Usually the X11 versions/configurations make the system unusable. In your case I guess that this change to the systemd configuration got changed.
Note that /dev/mmcblk0p1 is a partition on the eMMC device on the module. The SD card is represented by /dev/mmcblk1pX.
If you need additional help please state the version of things you use, both hardware and software.
Ok, if I do not update the system does not break.
I think thats not the case, correct me if I’m wrong, but imx6ull uses an NAND as primary non-volatile memory.
