I have inserted and SDCard into the Dahlia carrier board running Torizoncore 6. I am working with this board remotely at the moment, so I do not remember the size of the SD card that I put into the board. My issue is that the SD card is not automatically mounted. I think this has to do with the initial format of the card, with is exFat, but I don’t know.
When I do a df -h
, I get the following output:
Filesystem Size Used Avail Use% Mounted on
tmpfs 2.0G 25M 1.9G 2% /run
devtmpfs 1.7G 0 1.7G 0% /dev
/dev/disk/by-label/otaroot 29G 2.1G 25G 8% /sysroot
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 4.0M 0 4.0M 0% /sys/fs/cgroup
tmpfs 2.0G 4.0K 2.0G 1% /tmp
tmpfs 2.0G 12K 2.0G 1% /var/volatile
tmpfs 393M 0 393M 0% /run/user/1000
The command sudo fdisk -l
shows a bunch of ram devices as well as the following two mmc based devices.
Disk /dev/mmcblk2: 29.14 GiB, 31293702144 bytes, 61120512 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xa3273dcb
Device Boot Start End Sectors Size Id Type
/dev/mmcblk2p1 8192 61120511 61112320 29.1G 83 Linux
Disk /dev/mmcblk1: 119.08 GiB, 127865454592 bytes, 249737216 sectors
Disklabel type: dos
Disk identifier: 0x00000000
/dev/mmcblk1p1 32768 249737215 249704448 119.1G 7 HPFS/NTFS/exFAT
I think I need to reformat mmcblk1p1
, but I don’t know how. I am also not sure if this is the SD card or not. Additionally, mmcblk2
shows a size of 29.14G, and I assume the eMMC on the Verdin SOM is 4GB. The board boots from the eMMC device, so I don’t want to accidentally mess with that device. As I said, I am currently accessing the board remotely, and if I mess up the boot, I can’t fix it without a lot of expense in travel.
I probably have this completely wrong, so any help in figuring out how to get the SD card formatted and mounted would be most helpful.
