I am trying to re-flash an existing Toradex Colibri VF61 module (v1.1B), using the steps provided here. The flashing completes successfully, but on resetting the module, the monitor displays the following message.
“The current input is not supported by
the monitor display. Please change
your input timing to 1920x1200@60Hz or
any other monitor listed timing as per
the monitor specifications”
Now, I am aware that the default resolution when the module is flashed is VGA 640x480, and my monitor is able to support that. But if the resolution is lower than that, monitor won’t support it.
So, what I am concluding that the resolution on the module is not getting reset to the default 640x480, and what it is getting set to after flash, is lower than that.
Is there a way to fix this resolution by any other steps?
I am performing following steps to re-flash the device.
- Flashing the bootloader (from Eboot)
- Flashing the OS (BSP 1.3 and WinCE 7, including eraseflash filesystem)
Thank you.
