Save registry on WCE7 2.0 part 2
Dear Samuel.tx,
thank you for your answer.
I currently using .cfg file:
[device]
type=default
instance=0
[partition]
name=BCT
id=2
type=boot_config_table
allocation_policy=sequential
filesystem_type=basic
size=3145728
file_system_attribute=0
partition_attribute=0
allocation_attribute=8
percent_reserved=0
[partition]
name=PT
id=3
type=partition_table
size=4096
percent_reserved=0
[partition]
name=EBT
id=4
type=bootloader
size=4194304
percent_reserved=0
filename=EBOOT.NB0
[partition]
name=BMP
id=5
type=data
size=262144
filename=Splashscreen.bmz
percent_reserved=0
[partition]
name=CE6
id=7
type=data
size=104857600
percent_reserved=3
filename=NK_CE7.NB0
[partition]
name=ARG
id=8
type=data
size=2048
percent_reserved=5
start_location=0
[partition]
name=USR
id=13
type=data
size=0xFFFFFFFFFFFFFFFF
allocation_attribute=0
percent_reserved=5
Is there a mistake?
Thank you very much.
Best regards
Saphymo
Yes, there is a mistaked. For flashing CE 7 V2.0, this is not the correct file. Please get the latest Image 2.0 download and get the CE7.cfg from there. I have also attached it here for your.
If you compare your config with the one I have shared with you, you will see some missing sections in your version. One of the missing entries is the registry partition:
[partition]
name=REG
id=9
type=data
size=3145728
percent_reserved=5
start_location=0
Dear Samuel.tx,
I tryed the .cfg File from here
https://share.toradex.com/c1m1dayors4zz0u?direct
with the section
[partition]
name=REG
id=9
type=data
size=3145728
percent_reserved=5
start_location=0
but it doesnt run.
I send you the .cfg file and screenshot via email.
If I flash the Image in the package it works but my self created Image doesnt work.
I have no idea what is the reason.
Best regards
Saphymo
