Sending and save Text from in C# written program to USB (Stick) as a pdf File. Have tested Library’s from “iTextsharp” and “PdfText”. They work on PC (Win 7, 8 or 10) well, but not on Win CE. Gives there a library for Win CE?
Hi @Ziet_Tor_2005 ,
Unfortunately i have no experience with PDF creation and c#, but a quick google search gave me this link:
http://www.hjgode.de/wp/2009/10/31/itextsharp-running-on-compact-framework-windows-mobile/
Hope it helps
Hi @germano.tx
Thank You for the link. In this i found a itextsharpcf.dll library. After i referenced this library to my project, it runs well after some modification in the code. Itextsharpcf uses also dll-Names like System.Windows.Forms or System.Drawing. So You have to declare explicit it in the code from which one You use it.
