SATA Disk and mainline Linux Kernel 4.6.2
Dear Mr,
Do you have any patch available to enable sata driver for apalis T30 under mainstream kernel? If not what is the simplest way to make sata disk working?
Kamil
Well, I believe another customer once already tried integrating this in the device trees without success. I also had a quick look at it once and while the basic IP of the TK1 SATA controller seems similar to the T30 one the whole pin level bring-up is quite different. But of course while not entirely trivial writing a driver for it should be possible.
