Hi @sirhc ,
On first look there doesn’t seem to be any obvious mistake on your overlay.
On this solved topic: Device tree configuration for SGTL5000 audio codec someone had a very similar issue with SAI on iMX6ULL with SGTL5000. Can you try the proposed solution and see if it works for you?
Lucas Akira
